Help needed with flashing new ROM
    Hello all good people
    I have bought my first android stick and I am kinda satisfied with it, but I really want to root it and
    put one of finless roms and I'm stuck at identifing my stick and choosing rom for it.
    It says its RK30sdk with 2 cores (other software said one) (now Im using system info droid)
    on summary it says:
    Device: Rokchip rk30sdk
    Android: 4.1.1
    CPU Max Freq: 1602
    CPU cores: 2
    System RAM 882 (???)
    Display: 1280x672 (9.2inch)
    On gpu it says its mali-400 MP
    So please help me chooze right thing to flash to it
    Thank you all in advance, have nice day
    Picture of stick
    Hello
    I realized its mk809, I wasn sure but i opened it and on chip it says 3066,
    so finally i flashed rom that other guy reccomended for mk809 its ug802 2dark-finless rom but i have some issues with it
    1. can't get full root on some apps like reboot that is included in rom it says you don't have root acces
    2. same thing happens on some vnc softs
    3. but when I fire up terminal and SU it says #, so in TE i have root so i dont know whats happening
    So what to do should I try different ROM like iMito MX1/2 or UG802 ?
    Thank you
      Originally posted by UnknownUs3r View Post
      Hello
      Thank you
      Have you installed superuser.apk or supersu.apk?
      My devices:
      Gearbest.com)
        yes they are in finless rom 1.7 but i corrected all with ug802 1.8 rom but now other issue arise
        my droidmote doesnt work
