Polaroid P7200 with Market3.4.4 By Finless Version 1.4
Cannot log in after Using font changer
Hello,
Now I have a problem. First I want my tablet can render khmer unicode so I copy .so file to system/lib and .ttf file to system/font. Then change font by using font changer. after that when I reboot my tab cannot log in, it still display boot image. I press reset to shutdown and then I try to recovery by press volume up or down + home + power button, but it still not. so I want to ask
1). What is problem?
2). How to reflash recovery?
You will need to reflash the ROM using the flash tools.
Re: Polaroid P7200 with Market3.4.4 By Finless Version 1.4
Originally posted by CHEABKunthea View PostDear all!
I want to install nokora.ttf font in my tablet in order to render khmer unicode text. So shoud I do? thanks
Sent from my GT-I9100 using Tapatalk 2
Originally posted by Miss Dragon View Postim not sure if you can use winimage to exact the image file..if you can..then replace the .ttf font files whatever you chose.
You need to set the permissions on the file after you copy it. With root explorer press long on the file and select permissions. Just check all the boxes.
Download link in first post has been fixed.
There are currently 3443 users online. 1 members and 3442 guests.
