Touchscreen Drivers ? for Finless
Bob, I was reading where someone made virtual touchscreen drivers for the 808. See Here : http://www.dewmill.com/rikomagic.html . Is there any way you could do something like this for the X5. This would allow us to play almost any game if you can. The same guy said the PROBOX already came with virtual touchscreen drivers. Also wanted you to know thsat so far your new Rom is flawless. ThanksTags: None
Sure I can add that KO module in the future.
But you can easily do what he says and put it in.
Also if you want to do it automatically just copy the KO file into /system/lib/modules
Set the permissions the same as other ko modules
Make a init.d script and copy it into init.d
File name of the script should be 00touch
Put this in the script:
#!/system/bin/sh
insmod /system/lib/modules/virtual_touch.ntts.ko
Remember to put a blank line after the insmod command! If you don't it wont work.
Now every boot the driver will be loaded.Last edited by Finless; 05 April 2013, 19:40."Pzebacz im, bo nie wiedzą, co czynią"
Originally posted by Finless View PostSure I can add that KO module in the future.
File name of the script should be 00touch.sh
#!/system/bin/sh
This is what comes up when I try it in terminal emulator:
u0_a63@android:/ $ suu0_a63@android:/ # cd /sdcard/Download
u0_a63@android:/sdcard/Download # insmod virtual_touch.ntts.ko
insmod: can't open 'virtual_touch.ntts.ko'
255|u0_a63@android:/sdcard/Download #
I just tested it and it works... but I made a mistake in my instructions above which I just edited.
the script file name should be 01touch NOT 01touch.sh
so no file extension or it wont work
Also be sure to set permissions on the script. Using ES file explorer long press on the script file.
set permission: check all read boxes, check all write boxes except other, set all execute boxes.
Should work then.
To be sure install Android terminal emulator
at the prompt type
su
allow root when dialog pops up
now type
lsmod
it should list the touch driver
Also that guys instructions are not right for terminal emulator!
You cannot do it from sdcard because it is fat32 and does not have proper Linux permissions.
If you want to do it in a terminal emulator:
Get ES file explorer. Make sure to go into ES file explorer settings and turn on
root explorer
up to root
mount system RW
Copy the ko module to /system/lib/modules
To make it simple I renamed the ko file to touch.ko
Again set the permissions of the ko file the same as other ko files.
Using ES file explorer long press on the file name and select permissions in the list at the bottom
now open a terminal emulator
type
su
now type
insmod /system/lib/modules/touch.ko
To make sure it worked, type
lsmod
it should be listed
Originally posted by Finless View PostAlso that guys instructions are not right for terminal emulator!
root explorer
up to root
mount system RW
type
su
now type
lsmodh
it should be listed
Which ROM?
Please try it with minix stock ROM my 1.2 was made from (their latest ROM).
Nothing I did should have made it not work IF it works in the stock ROM. Possibly Minix left out a driver.
Originally posted by Finless View PostPlease try it with minix stock ROM my 1.2 was made from (their latest ROM).
Wait..... I bet I know why. There are 3 full sized USB ports. Try one of the set of 2 on the side not the full sized single one next to the MIC and headset jacks.
Some of these are HOST ports and some are not. Micro USB port for instance is not a Host port.
I noticed in the new ROM in XML permissions there was no HOST USB defined.
So again try other full sized USB ports. If it still does not work, I will see if I can fix it.
bob"Pzebacz im, bo nie wiedzą, co czynią"
Originally posted by Finless View PostWait..... I bet I know why. There are 3 full sized USB ports. Try one of the set of 2 on the side not the full sized single one next to the MIC and headset jacks.
bob
Bob, I noticed when i turn on usb/bt joy center at the top it goes through a list of what it is doing. One of the things it says is that its checking usb permissions,then it says no usb/bt device found, but on kirks rom it pops up a box and asks for usb permission then after i click ok it shows my gamepad. I dont get the pop up box with your rom or minix rom.
My 1.0 ROM and Kirks ROM are made from the same version so both should work.
However as you see Minix broke something with the new ROM and thus it is in my 1.2 ROM as well.
I will investigate and see if I can repeat the issue and fix it for Minix
I think I know what it is.
OK so here is the deal.
I do not own a BT controller so I have never used six axis APP before nor do I own it.
When I run the six axis compatibility APP from Google Play it "says" it appears to be supported by this ROM and gives a BT address. But since I do not have a controller, I cannot test farther or determine what the issue is.
Now when you say you have tried all the USB ports, what do you mean? With what? A USB dongle or something?
When I asked you that question I was thinking Joy Center APP which is made for USB controllers. So now I am confused a little about what your setup is?
There are currently 2254 users online. 1 members and 2253 guests.
