How to get bigger ?
How to get bigger ?
Just wondering if there are any emulators that I can play on my x5 that dont have to be tiny to have good quality graphics ? Or am i doing something wrong ? I am on a 60 inch tv and for example supergnes looks terrible unless i play with screen on normal and then its only about a 15 inch square. Otherwise it stretches it so bad you cant play.Tags: None
well, I don't know about that particular emulator but usualy emulators come with all sorts of filters available.
Stretching the "tiny" SNES resoltuion to a full HD Display will always result in a blurry/blocky/ugly image. The filters are there to help lessen this problem but may not get rid of the issue completely.
EDIT: Also, you do not want to stretch the 4:3 aspect ratio of the SNES resolution to the 16:9 aspect of your TV. That would make the image even worse. What I suggest is to let the emulator keep the 4:3 ratio and instead display black bars on the left and right of the image.
There are currently 1031 users online. 0 members and 1031 guests.
