using init.d to wifi install module
    hi all
    i got tp-link 723 v2 usb stick ,works perfectly using a.alekizoglou driver, but i have problem with start driver module on startup
    i renamed file to rkwifi.ko in system/lib/modules/ but what i can see is internal wifi still start , why??
    my module name now is rtwifitp.ko
    i can use terminal to insmod driver, i tried to use init.d and maked script named wifi.sh, here in attachment but it's not startup
    how can i replace internal wifi driver or what method can i use?
    Try removing the .sh file extension.
    900Supersport
    freaktab developer
      i tried same result
      u can find attachment file
        Re: using init.d to wifi install module
        just put the module in its original name. you dont have to rename it to rkwifi.ko
        here's my init.d script for my dongle
        Code:
        #!/system/bin/sh
        su
        insmod /system/lib/modules/rtl8192cu.ko
        Sent from my GT-I9100 using Tapatalk 2
          thank you , it's work
          Code:
          #!/system/bin/sh
          su
