I have just found a problem. I have an app, the screen should be set to the portrait orientation, but it won´t work in the ROM. I have tried the latest MK808 JB 4.2.2 - Finless ROM 2.0, but it it doesn't work either. Has someone an idea to solve the problem?
MK808-how to enable the screen rotation
Hello,
I have just found a problem. I have an app, the screen should be set to the portrait orientation, but it won´t work in the ROM. I have tried the latest MK808 JB 4.2.2 - Finless ROM 2.0, but it it doesn't work either. Has someone an idea to solve the problem? -
In my ROMs you can force a rotation using build.prop
ro.fs.rotation=
However auto rotation is disabled in ALL TV ROMs to keep apps from rotating! People do not want a rotated screen on a TV!
It can be enabled though via code changes.
Originally posted by Midniteoyl View PostJust trying to figure out which apps look better in portrait on the TV...? I have an app that will ONLY do portrait on my tablets, but shows properly in landscape on the 808B.
Originally posted by t-bon3 View PostBBC Radio is an example of an app where important controls are offscreen in ladscape mode https://play.google.com/store/apps/d....apps.bbcRadio
Originally posted by Finless View PostIn my ROMs you can force a rotation using build.prop
ro.fs.rotation=
I have added it to the build.prop but it still dosen´t work. Did I miss something?
Me too would enable the auto-rotate for some applications. (ex VideoMediaset italy app)
On my Nexus 7, the application starts in portrait, but when I select the fullscreen, remaining in landscape, the video looks good and is optimized for the landscape.
Sull'MK808B is set with ro.fs.hwrotation = 270 and fakerotatione = true.
The application starts in landscape (but is not suitable for landscape) so it is enlarged and you can not scroll down to select the fullscreen video.
I tried to rotate 0,90,180,270: D and fakerotation = true and false, all combinations, but without a good result.
Is there a way to keep the MK808 as a Tablet giving the opportunity to start in portrait for some applications?
But most important thing is there a way to run the various applications that are on Playstore for the rotation (and forcing)?
Sorry for my bad English: DLast edited by Mandrake2; 17 April 2013, 17:05.
There are currently 4231 users online. 1 members and 4230 guests.
