705x Netflix won't load
Originally posted by hootowlserenade View PostI don't have any issues running netflix on my pmid705x, however I am running elektrik's rom on it. If you don't mind downgrading your tablet to ICS, his rom makes the tablet run a lot smoother.
Snapped from my Elektrik Polaroid PMID705X
Re: 705x Netflix won't load
There is everything you need to know... make sure to follow directions listed... make sure you install all the drivers on your computer... my win7 PC was a little quirky, I had to install the 32 bit drivers and put them in compatibility mode for my 64 bit system... either way just remember that no one here is responsible if you do something wrong *standard disclaimer*
Just read everything before you start the process and you should be fine. Also remember that once you install elektrik's ROM there is no going back to JB until polaroid releases the IMG file for JB (they still have the ICS file though, and I ran that before installing elektrik's ROM, it works about as good as JB anyway)
Sent from the cutting edge of my Droid RAZR MAXX
There are currently 3007 users online. 1 members and 3006 guests.
