Ployer MOMO7 GingerBread - Custom ROM by Finless Version 1.4 with Market3.4.4
    OK so the latest ROM for the MOMO7 from Ployer is Honeycomb OS. Some may not like it. The previous release from Ployer was Gingerbread 2.3.1 which is what most of the China tablets are running today. Stock it is SLOW as we all know. However many that are now using my 1.4 ROMs know the difference I have made to Gingerbread.
    By request, hereis the Gingerbread ROM for the MOMO7 with my 1.4 adds and updates.
    FYI, this time I cannot flash this ROM to test for a brick. It simply will not boot on my Arnova which is odd for sure. So your on your own. I hope I did not make a brick ROM but I am pretty sure it will work. Let me know if not.
    ____________________________________________
    WARNING! Remove your SDCard when flashing this ROM!!! There is a risk it can be ERASED!!!
    This has been a lot of work by many other people. I HAVE to give total PROPS to FreakTab user Fenice57. His first ext4 setup was not quite right. We all worked together and Fenice solved the problem by highly modifying the recovery system.
    ext4 explanation:
    Understand the history. After a ROM flash the recovery system formats everything. Well without a change in that it simply reformatted anything back to ext3. The ext4.ko kernel modules handled mounting an ext3 partition even if the mount command said to mount as ext4!!! It even reported it mounted as ext4!!! Go figure that one So lot's of testing and benchmarking later..... We have a real ext4 file system!
    So there was no ext4 file system to benefit from in previous work. The improved ext4 kernel modules gave a little performance add but not much. However Fenice57 worked HARD on solving this and modified the recovery system to stop the format to ext3. Sowa and myself also added in testing and showing the issues. But Fenice is the MAN! He solved it.
    Fenice57... Can I just say THANK YOU! Everyone that uses my 1.4 ROM. Please also give a hand to Fenie57!
    OK so what’s in this ROM 1.4
    It's the same as 1.3
    1) Full root with /system set as RW
    2) SU and Superuser.apk installed and given root permissions
    3) File system properly redone and blocked for NAND.
    4) Market 3.4.4 installed
    Whats added in 1.4 is:
    1) WiFi scan interval is changed from 15 seconds to 300. This may help some guys with battery issues. Myself, I do not have this problem but due to many asking for it, I put it in. If you want to change it back:
    Use a file manager and copy out from /system the file build.prop file. Copy it on your SDCard. Then copy to PC or whatever. Edit the file and find this line:
    wifi.supplicant_scan_interval=300
    Just edit the 300 back to 15 and your back to stock.
    2) ext4 file system.. Well I explained the work that went into this above but just to add. I have done extensive benchmarking with many tools. This does not add a huge performance increase to the overall use of the tablet. EXCEPT, and this is actually kind of benefit, Sequential Write of files to memory. Large file writes are over double what they were on ext3. Random Read and Random Write are about the same. So where you should see an increase is downloads to Tablet memory, market download and install speed, some apps that write to memory a lot, etc etc etc. Overall however, the tablet seems much faster to me but remember, I am the cooker so I am biased
    Ok well that’s it. I was working on a dual boot setup but that will have to wait for 1.5
    Here is the download link for 1.4
    ROM -> Ployer MOMO7 GingerBread version 1.4 by Finless (130 megs)
    IF YOU HAVE PROBLEMS WITH ANDROID MARKET
    Market issues. Market issue "may" still exist. This is common on tablets that are not really supported by Google as a registered device. Most users have no issues but sometimes there can be, The 2 issues that seem to arise when your FIRST TIME try to use the Market are:
    A) Cannot logon; "Cannot establish a reliable data connection" I have tried to recreate this and troubleshoot this. My belief if in fact this happens sometimes when Google servers are doing something or something is going on with them. When I had this happen once I simply waited a while and it worked later. So I cannot help too much here. My only suggestion to try is this
    a) Install a root file manager like root explorer or ES file manager (enable root access for them)
    b) Go in with the file manager and delete /data/misc/imei/imei or data.dat which ever one exists
    B) Limited apps listed; I have reproduced this and know how to recreate it and fix it! This has to do (I beleive) that after a factory reset or a flash the tablet creates a ID based on some other IDs and a random key generator. Sometimes this ID Google does not like. So we have to clear that and reboot. YOU DO NOT EVER NEED TO REFLASH OR DO A FACOTRY RESET TO FIX THIS!!!!
    DO the following
    a) Again using a file manager that has root access go in and delete the follow folders from the /data/data directory.
    com.android.vending (not com.applib.vending!)
    com.android.vending.updater
    com.google.android.gm
    com.google.android.gsf
    b) Reboot and do nothing else but run the Market. YOu should get a prompt asking you to accept the Google terms of service. If you did not you did something wrong. Do it again. If you do get the prompt, accept and now the Market should work fully with TONS of apps showing up.
    OK so thats it.... I hope you enjoy my new ROM. Please feel free
    Again, this ROM was a combined effort from a few people and I could not have done it without them!
    Oh and also....special thanks to Freaktab user Daman for an awesome boot screen and a LOW COST boot animation that will show people if the Tab is bricked or actually booting! When I say a low cost boot animation I tested it. With out it the boot time was only 4 seconds longer! But the beauty is unlike complex boot animations out there, this one gives the user feedback showing something is happening rather than wondering if it is a brick! GOOD JOB Daman and thank you!
    If you the user wants to remove it, since you are rooted , just go into /system/media and delete the file bootanimation.zip. But I think you may find you like it so I personally enjoy it and will keep it
    Tutorial for installing drivers for flashing-http://www.freaktab.com/showthread.p...-for-flashing!
    Enjoy!
    Damo - Forum Moderator
    PLEASE CLICK THE DONATE LINK BELOW
    PS
    If you are having trouble with the above link when using Tapatalk than here is the email link for donations below
    https://www.paypal.com/cgi-bin/websc...=ZYCM4NZ4J6F3G
    Thank You
    great..
    Hi Finles..great work on your custom rom...i already try all your rom posted in here, now my momo7 can boot up, the thing is, the touch screen is not responding on all the rom, is my tablet damage?
    is there a way to fix this?
    thank you before...
      Is your tablet actually a momo7?
        MOMO 7
        Hi Bob,
        thx for replying, Yes it's momo 7 from ployer, i bought it when i go to guangzhou. but it's the first model, not like the momo7bird in ployer website.
        i try the GB fw but stuck in the boot logo. on the honeycomb it running ok, except the touch screen not working.
        is there a chance this a hardware error, or it can be fix on software.
        because after a week it's suddenly the os is froze, and the it cannot boot up. since then i try so many FW but all of them the touch screen not work.
        pls advise
        thx u
          If the screen does not work then you have a different model than the Stock ROM I used to make tis rooted ROM.
          Is there a stock rom download that works on your tablet? If so I can make a ROM from it.
            HI BOB,
            all the rom, either the stock or custom i try all giving me same issue, no touch screen.
            i'm beginning to think that my touch screen hardware is broken.
            the rom that work is all honeycomb version, even your GB version is stop on the boot logo.
            although if i use the usb on the go with mouse it's all working.
            is there any other GB rom that i can try??
            or any way to fix the touchscreen issue?
