Are Apple Magic Mouse or logitech t620 compatible?
    Hi all
    I own a MK808B and I'm looking for a new touch mouse for my laptop an if possible for the tv dongle.
    I must decide between logitech t620 and Apple magic mouse, both are multitouch mouse.
    The pro of Apple MM is the bluetooth so I can connect to the mk808b trough the bluetooth radio
    The Logitech has a usb pin to be moved from the laptop and the dongle.
    Does anyone had any experience with these mouses?
    Thnx
    Pietro
    T650 touchpad sort of works
    I know it's not exactly what you asked...
    Logitech T650 touchpad mostly works. It uses the same unifying receiver and setpoint software on Windows, so I figured it was applicable and possibly helpful. No pinch to zoom. Cursor control works. Left and right click work. Two finger scrolling works. I would make a small wager the T620 will work as a regular mouse fine, just no additional touch controls that might work fine on Windows 8.
      T620 and t650 are made by the same producer and I think they'll have similar technologies..
      So may be t620 will work similar to t650, no?
      Thanks for your reply.
      My question now is if the magic mouse (apple) will work with mk808b.
      It would be great because of the usb connection (no need to plug/unplug the wifi receiver).
      Ciao
      Pietro
