Arnova 7G2 Custom ROM with Market3.4.4 by Finless Version 1.4
    OK this is for you 7G2 folks that want my version of the 7G2 1.4 ROM. ALso check out Fenice57's ROM. He has added goodies in his I did not put in mine.
    WARNING! This is one of the few ROMs that will not work on my 10G2. I have no way to test if this is a brick ROM. If it is I have made 7G2 ROMs before so I know I can fix it. But I am not 100% sure this will work so read posts below about users that tried it and if it works.
    ______________________________________
    WARNING! Remove your SDCard when flashing this ROM!!! There is a risk it can be ERASED!!!
    This has been a lot of work by many other people. I HAVE to give total PROPS to FreakTab user Fenice57. His first ext4 setup was not quite right. We all worked together and Fenice solved the problem by highly modifying the recovery system.
    ext4 explanation:
    Understand the history. After a ROM flash the recovery system formats everything. Well without a change in that it simply reformatted anything back to ext3. The ext4.ko kernel modules handled mounting an ext3 partition even if the mount command said to mount as ext4!!! It even reported it mounted as ext4!!! Go figure that one So lot's of testing and benchmarking later..... We have a real ext4 file system!
    So there was no ext4 file system to benefit from in previous work. The improved ext4 kernel modules gave a little performance add but not much. However Fenice57 worked HARD on solving this and modified the recovery system to stop the format to ext3. Sowa and myself also added in testing and showing the issues. But Fenice is the MAN! He solved it.
    Fenice57... Can I just say THANK YOU! Everyone that uses my 1.4 ROM. Please also give a hand to Fenie57!
    OK so what’s in this ROM 1.4
    It's the same as 1.3 with a couple more tweaks on my part based on user feedback and a couple of other slim downs in code I have done to init.rc, updated lib modules, etc.
    1) WiFi scan interval is changed from 15 seconds to 300. This may help some guys with battery issues. Myself, I do not have this problem but due to many asking for it, I put it in. If you want to change it back:
    Use a file manager and copy out from /system the file build.prop file. Copy it on your SDCard. Then copy to PC or whatever. Edit the file and find this line:
    wifi.supplicant_scan_interval=300
    Just edit the 300 back to 15 and your back to stock.
    2) ext4 file system.. Well I explained the work that went into this above but just to add. I have done extensive benchmarking with many tools. This does not add a huge performance increase to the overall use of the tablet. EXCEPT, and this is actually kind of benefit, Sequential Write of files to memory. Large file writes are over double what they were on ext3. Random Read and Random Write are about the same. So where you should see an increase is downloads to Tablet memory, market download and install speed, some apps that write to memory a lot, etc etc etc. Overall however, the tablet seems much faster to me but remember, I am the cooker so I am biased
    3) Because of popular use of Hauwei 3G sticks in Europe and Asia, I added this Fenice57 mods for support of this. I cannot and have no way to test this patch. So hopefully I implemented this properly. You guys I am sure will let me know
    3g USB-modem Hauwei models E1550 E1692 E1750 E1820 *
    Ok well that’s it. I was working on a dual boot setup but that will have to wait for 1.5
    Here is the download link for 1.4
    ROM -> Arnova 7G2 rooted version 1.4 by Finless (80 megs)
    IF YOU HAVE PROBLEMS WITH ANDROID MARKET
    Market issues. Market issue "may" still exist. This is common on tablets that are not really supported by Google as a registered device. Most users have no issues but sometimes there can be, The 2 issues that seem to arise when your FIRST TIME try to use the Market are:
    A) Cannot logon; "Cannot establish a reliable data connection" I have tried to recreate this and troubleshoot this. My belief if in fact this happens sometimes when Google servers are doing something or something is going on with them. When I had this happen once I simply waited a while and it worked later. So I cannot help too much here. My only suggestion to try is this
    a) Install a root file manager like root explorer or ES file manager (enable root access for them)
    b) Go in with the file manager and delete /data/misc/imei/imei or data.dat which ever one exists
    B) Limited apps listed; I have reproduced this and know how to recreate it and fix it! This has to do (I beleive) that after a factory reset or a flash the tablet creates a ID based on some other IDs and a random key generator. Sometimes this ID Google does not like. So we have to clear that and reboot. YOU DO NOT EVER NEED TO REFLASH OR DO A FACOTRY RESET TO FIX THIS!!!!
    DO the following
    a) Again using a file manager that has root access go in and delete the follow folders from the /data/data directory.
    com.android.vending (not com.applib.vending!)
    com.android.vending.updater
    com.google.android.gm
    com.google.android.gsf
    b) Reboot and do nothing else but run the Market. YOu should get a prompt asking you to accept the Google terms of service. If you did not you did something wrong. Do it again. If you do get the prompt, accept and now the Market should work fully with TONS of apps showing up.
    OK so thats it.... I hope you enjoy my new ROM. Please feel free
    Again, this ROM was a combined effort from a few people and I could not have done it without them!
    Oh and also....special thanks to Freaktab user Daman for an awesome boot screen and a LOW COST boot animation that will show people if the Tab is bricked or actually booting! When I say a low cost boot animation I tested it. With out it the boot time was only 4 seconds longer! But the beauty is unlike complex boot animations out there, this one gives the user feedback showing something is happening rather than wondering if it is a brick! GOOD JOB Daman and thank you!
    If you the user wants to remove it, since you are rooted , just go into /system/media and delete the file bootanimation.zip. But I think you may find you like it so I personally enjoy it and will keep it
    Tutorial for installing drivers for flashing-http://www.freaktab.com/showthread.p...-for-flashing!
    Damo - Forum Moderator
    PLEASE CLICK THE DONATE LINK BELOW
    PS
    If you are having trouble with the above link when using Tapatalk than here is the email link for donations below
    https://www.paypal.com/cgi-bin/websc...=ZYCM4NZ4J6F3G
    Thank You
    Hi Bob. Thank you very much for this update. I've been waiting for this. I do have one question, are you using Fenice's recovery.img on this rom?. Thanks
    TURBO
      TURBO
      Yes and no. I edited the recovery myself from his teachings. This is not the one that gives you the recovery menu with a touch screen that actually works. I have that recovery as well and will be trying to see if I can make a CWM mod.
        Working wondeful.Fast boot. Beautiful boot image. Fast navigation. Just wonderful
        thank you for the hard work
          Thank you for let me know. I tested that recovery.img. It does what it should but I dont like the behavior that if you connect the G2 after you lock the button, it will erase user data and cache automatically without warning. Grrrr. After you spend time configuring everything....Well. I will have to replace the recovery.img with the touch screen one that I have.
          So far, I love your ROM. It's stable and doesnt have bloatware. Everything else can be added from the Market. I dont know why all Linux developers doesnt follow this principle. If I were a Linux developer, I would create a distro where all basic functions would work and users add all the apps they want from the market place. Thanks again for your work.
          TURBO
            TURBO
            My ROM does this?
            Pleae explain more exactly what is happening. I have a 10G2 with this recovery and I am not having any problem like this. But of course we do not have a lock button.
            If I understood this better I might be able to solve it.
              My ROM does this?
              Hi Bob. Yes, basically to replicate it, please do these:
              1) Turn off the 7G2
              2) Lock the 7G2 (move the lock button to the right)
              3) Connect the G2 to the AC power
              4) 7G2 will turn on automatically
              5) Recovery will format automatically /DATA and /CACHE without warning
              6 ) You will loose all the settings you configured and device will load default settings
              With the touch screen recovery.img, basically it goes to the menu, but doesnt delete the settings automatically.
              Thank you, chief.
              TURBO
                That is very odd... I do not understand why it is going into recovery just from plugging it in?
                So I guess I should remake the ROM with that to save people from this problem.
                  Hi Bob. That would be great. If my logic is correct, a "Want to wipe?" prompt before wiping, would do the trick. User would select yes or not. Well, you are the master on that.
                  Million thanks.
                    TURBO, please check this issue. I am not using Fenice original recovery system that goes into recovery automatically. At least I do not think so. In fact it bypasses it in order to get ext4 formatted.
                    I know you probably dont want to erase /data to find out but since I dont have a 7G2 I cannot cause you situation. However I cannot force my 10G2 into recovery with this setup so I believe this is solved already.
                      HI Bob. I checked and and double checked this issue with the 7G2 AND V1.4. Others can confirm this. Using the previous steps, all your /data and /cache will be wiped out. Only in the 7G2, apparently. That's why I asked you about the Fenice57 rom, since this one did the same. If you want, you can put a disclamer in the OP threat about this. As long as people knows.
                      The problem I see is that the lock button is the same button you use in the 7G2 to turn it on / off. So if you by mistake, lock it up and connect it to the AC it will go to recovery and wipe data. Je, je..That happened to me with Fenice's one, until I discovered another rom and took the recovery utility (recovery.img v1.3.38). This particular one is the one with the touch screen and works wonderful with your ROM. The trick is that goes straight to the menu. You can select Reboot system now, Factory reset, SYSTEM recover or Update from SDCARD.
                      Thank you.
                      TURBO
                        Yes I have that recovery system and it is what I am using to try and make a CWM mod.
                        However you have to understand the MISC.img plays a part in this by telling recovery what to do on reboots etc.
                        So you have confirmed this issue in my ROM? It is not the same as Fenice's. If you have I can give you a misc.img and see if it solves it if your willing to test.
                          Sure, post it. I will like to test it. Thank you
                            OK you only need to flash misc.img. So in the flash tool uncheck everything except misc.img.
                              Hi Bob. This is the behavior after I flash this misc.img
                              1) I lock the 7G2
                              2) I plug the 7g2 to AC
                              3) 7G2 Turns on automatically
                              4) It shows "Formatting to CACHE !"
                              5) It shows "Formatting to DATA !"
                              6) Recovery Menu applears with the options
                              7) I click on confirm "reboot system" and system reboots.
                              8) All previous settings were wiped and default settings loaded.
                              I noticed that in v1.3 it went straight to the menu and did not perform "Formatting to CACHE/DATA". That scrypt is at the very begining and is wiping everything automaically, even prior the recovery menu..
                              I hope this gives you a clue what is happening.
                              Thank you.
