[ROM] KIRk Out!! NEO X5 G4 4.1.1_0117 {v 1.6}
    ok ladies and gents...this is ONLY!! for install with CWM.
    Whenever there is a new MAJOR firmware release to a new version of Android (i.e. going from 4.1.x to 4.2.x), I will say push the firmware to your X5 and then you can reinstall CWM. That way the RKBatchTool will do a low level format of the NAND and keep your system running smooth.
    CREDITS go out to Minix for making this stellar rom used as a base!!
    UPDATE (2/16/13): ok so I finally got the formatting script working and it formats ALL the partitions correctly into ext4 format. It turns out that it was mostly related to the CWM previous releases were not able to format ext4 correctly and I believe also because the system partition was never really a true ext4 format. Well all is well now with the last 2 new releases from fun_, and from now on I will have a new setup on how to install my roms and keep up with the new firmware of Minix without having to go through all the hassle of reinstalling CWM and what not. I will drop my new roms later on...its 2:30am here right now and i'm bout to sleep now. Laters!!
    UPDATE (2/18/13): now you will have the option to change kernels after my rom is installed or before or whatever you want to do. As always, make a backup first cuz I'm not responsible for you losing your stuff. Read below for more info.
    UPDATE (3/07/13): Most likely this weekend, after some testing of course, I will be changing the way we install the kernels for use with my roms, so look out for that!
    UPDATE (4/08/13): I have refrained from updating to the new firmware until Minix fixes a few of the bugs. They said sometime this week, so we will see. Until then I have changed a few things, but more importantly how to flash everything.
    UPDATE (4/11/2013): Sorry guys!! I have re-uploaded the stuff for the NEO G4 cuz I forgot to change the boot.img and kernel.img files for the NEO G4. Once again, sorry about that. Just reflash to the new one specific to your device!
    Well without further ado...here it is folks!!
    WARNING!!: Please READ and PAY ATTENTION!! Make sure you download the correct file for your correct device. I take no responsibility if you screw things up with your device!
    Current Release - v 1.6
    FULL ROMS with included kernels (for those that are new to my rom that want a complete package):
    http://d-h.st/B2O Neo X5 ONLY!! 1080p kernel
    http://d-h.st/o0F Neo G4 ONLY!! 1080p kernel
    http://d-h.st/4wj Neo X5 ONLY!! 720p kernel
    http://d-h.st/ezO Neo G4 ONLY!! 720p kernel
    ROMS only for Neo X5 & G4, NO kernel (for those that are already on my rom and the kernel they want, but just want to update):
    http://d-h.st/DN1 1080p ONLY!!
    http://d-h.st/8Vk 720p ONLY!!
    KERNEL UPDATERS (for those that just want to change the kernel around, to be flashed in CWM only!!):
    http://d-h.st/YGM Neo X5 ONLY!! 1080p kernel
    http://d-h.st/2xH Neo G4 ONLY!! 1080p kernel
    http://d-h.st/UWnNeo X5 ONLY!! 720p kernel
    http://d-h.st/lvY Neo G4 ONLY!! 720p kernel
    Changelog:
    Code:
    v 0.9a - Initial testing - thanks to those that tested!!
    v 1.0 - First release
    v 1.1 - updated apps and added Gameloft fixes
    v 1.2 - updated more apps and su & busybox
    v 1.3 - removed some apps and changed a few things.  sorry...had to re-upload cuz of some errors.
    v 1.4 - fixed my formatting scripts, so the system and data partitions will now be true ext4 format.  Updated some apps.  removed Grid Launcher.  fixed inverted Google Play store.
    v 1.5 - removed some apps, added some apps, and updated some apps.  a few build.prop edits.  added libstagefright.so from Rockchip (you will have to install advancedsettings.xml manually if you want it).
    v 1.6 - added XBMC Gotham hw accel apk to compliment the hw accelerated libstagefright.so, changed the way we flash my rom and kernels, updated some apps, and enabled lockscreen by default.
    What is has in it:
    Code:
    Rooted!Bloatware removed
    Gameloft fix  (credits Christian Troy)
    build.prop edits  (just minor ones so that most games work, but sorry...no Tegra 3 games.  Also these DO NOT work with Sopcast app)
    Apex Launcher (updated)
    Inverted Google Play - fixed and now able to buy apps  (credits Bad Seed Customs)
    Inverted Google Now - updated to newest  (credits B-Boy)
    Data added with some hopefully useful apps, don't worry they can be uninstalled
    Screen filter app
    init.d support  (if you guys want to add tweaks, I will add my own later, but for now...)
    YouTube 4.1.47 with full HD/full screen support
    QuickBoot (updated)
    updated apps including the newest SuperSU (updated again...sheesh!) & binary (again)
    Removed Root Explorer (sorry guys, thats mine!)
    Added Rom Toolbox Lite
    Added EStrongs File Explorer
    Updated busybox to newest 1.21.0
    Added Xbox gamepad codes (credits to Mow and the original xda thread)
    Removed Pandora, I added separate links for 2 different versions
    Added Inverted Dropbox - updated to newest (Bad Seed Customs at it again...those guys are the ish!)
    Removed Grid Launcher
    Added format scripts into the rom during flash through CWM
    Removed Screen Filter app (was causing video stutter)
    Removed CPU Identifier
    Updated AdFree
    Updated inverted Google Play Store (credits Bad Seed Customs)
    Updated SuperSU & binary again!
    Added a few more build.prop edits
    Added libstagefright.so from Rockchip for hw acceleration (I left original there as well just in case), you will need to add advancedsettings.xml manually if you want it - see post #2
    Added XBMC Gotham hw accelerated apk
    Enabled lockscreen (credits Finless Bob, thanks man!)
    Updated to koush's Superuser app and removed ChainDD's version
    Added new bootanimation (made by me! I will work on the quality as time goes on)
    What it doesn't have in it:
    Code:
    see the NOTE below
    5.1 Optical S/PDIF...yet...
    NOTE: Or you can use my kernel flashing zip, but you use that at your own risk. Downloads are below in post #2.
    I have updated the way we flash the kernels again, so you can use the ones from above if you feel the need to change kernels.
    NOTE 2: Apex Launcher is the only home launcher that is installed, so if you want a different launcher, make sure you install another one FIRST before you delete Apex Launcher.
    Installation instructions:
    1) Copy the .zip to your X5
    2) Reboot into CWM
    3) Click on "Install zip from SD Card"
    4) Select the .zip and wait
    You no longer have to wipe, as my rom will wipe and format automatically...so still do a backup before you flash!!
    If you guys find anything, let me know. Also, if you want me to add anything or look into something let me know as well...thanks and I hope you enjoy!!
    Source:
    http://www.minixforums.com/threads/r...117-v-1-6.313/
    Rockin' the 'ish outta Android!!
    KIRk Out!!
    XBMC:
    Delete the ".txt" off of "advancedsettings.xml.txt" below to make it "advancedsettings.xml". You will need to put it in your "sdcard/Android/data/org.xbmc.xbmc/files/.xbmc/userdata" folder using a file explorer app. Viola!! Now koying's blacklisting is disabled
    refer to this thread for more info...http://forum.xbmc.org/showthread.php?tid=152005
    page 32 of the thread will have more advancedsettings options.
    NOTE: You must have installed the xbmc hw accel apk from xbmc.org and run it FIRST before you will see the "userdata" folder above!
    KERNEL FLASHES:
    I have decided to keep these here for the people who do not have or do not want CWM recovery (you can uncheck the "recovery" box if you do not want CWM).
    IMPORTANT!!: PLEASE READ THE INSTRUCTIONS INSIDE FIRST BEFORE FLASHING THESE!!
    These zips contain the newest CWM recovery, so it is recommended that if you are coming from Finless's rom or Jazz's rom to flash one of these FIRST and then boot into recovery and then flash my rom. Like always, there is a disclaimer...don't blame me for ish if your device catches on fire!
    720p kernel:
    http://d-h.st/RrC Neo X5 ONLY!!
    http://d-h.st/wWF Neo G4 ONLY!!
    1080p kernel:
    http://d-h.st/9Dk Neo X5 ONLY!!
    http://d-h.st/e6N Neo G4 ONLY!!
    MODS:
    White mouse cursor from 4.0.4 ICS build but with blue and black tip that I made zip flashable through CWM.
    http://d-h.st/g8y
    Lockscreen
    Enabled - this is enabled by default in my rom
    http://d-h.st/yH7
    Lockscreen
    Disabled - just in case people want it for some reason
    http://d-h.st/6ew
    NOTE: These are only flashable through CWM. The lockscreen will need to be reset after each reboot! This is for JB 4.1.1_0117 only guys and I have only tested this on the 1080p kernel(though it shouldn't matter what kernel you're on), so please make a backup before flashing this...you have been warned!!
    CREDITS: All credits go out to Finless Bob for showing me how to do the lockscreen mod and letting me use this for my rom, much thanks!!
    KIRk Out!!
      APPS:
      Inverted Pandora - with girl in background (credits Bad Seed Customs)
      http://d-h.st/N3I
      Inverted Pandora - girlfriend safe!! (also credits to Bad Seed Customs)
      http://d-h.st/sQo
      KIRk Out!!
        ONLY THANKS TO YOU WORK
        [QUOTE=onelovekir;61347]ok ladies and gents...this is ONLY!! for install with CWM.
        THX to you onelovekir
          [QUOTE=payright57;61656]
          you're welcome! oh and sorry everybody...I have fixed the errors for anyone trying this rom on the G4. new links in the OP!
          KIRk Out!!
            3G dongle key - mobile networks - BROKEN?
            OneLoveKir, I found (on both kernels) that is not possible to set my 3G internet external key, because when i choose (under settings) the mobile networks, the "settings app" terms abnormally.
            Is it a your decision to take out the or it is a bug?
            thx for your answer
            G
              My g4 is scheduled to be delivered tomorrow and wanted to know how is ROM is running being that the last post was back in April (that's usually a good sign). Also I have a Plasma TV (720p) should i use the 720 ROM&Kernel?
                thx for your answer
                G
                Any answer? :-)
                G
                  hi. i use your rom 720p for my old minix neo x5. great rom of course some bugs are present.but for me
                  is the best custom rom. no reboots.rom is clean
                  thanks a lot
