OLD MK808/MK808B/MINIX Hybryd FW V2.2.2 (25.04.2013)
    This is modified Minix Neo x5 firmware with my tweaks.
    If anyone have question just ask
    !Google TV Apps Can Be Downloaded From My Website!
    My website:
    http://xbmcfreak.xorg.pl
    Beta:
    MK808/MK808B (Fixed)
    Dev-Host V2.2.2 480p (No BT Dongle support for 480p)
    Dev-Host V2.2.2 720p
    Dev-Host V2.2.2 1080p
    Neo X5
    Neo G4
    Cabletech
    Dev-Host V2.2.2 720p Fixed
    changelog:
    V2.2.2
    -better performance
    -faster boot up
    -youtube for gtv updated to 1.6
    -tv launcher
    -build.prop fixes
    -fixed touch emulation
    -new modules loaded at startup:
    Code:
        8723au.ko
        cx82310_eth.ko
        dm9601.ko
        smsc75xx.ko
        smsc95xx.ko
    V2.2.0
    -NeoX5 +NeoG4 Support
    -based on 26.03.2013FW
    -rooted
    -build.prop changes
    -gameloft games fix
    -logitech C series webcams best suport
    -virtual touchscreen suport (apps like sixaxis can mapp touch events, degre need to be changed to -90 in sixaxis settings)
    -usb bluetooth dongle support for mk808 (working randomly)
    -new bootanimation
    -stock kernel (you can flash any other kernel but bluetooth dongle will not work anymore)
    -app space 2gb
    -more space on launcher screen
    -cifs auto mount on startup (edit /system/etc/install-recovery.sh and put there your server ip, username, etc. change permisions to rwx --- ---)
    -libstagefright.so (new for better xbmc and other players compatibility)
    -youtube for gtv
    -wallbase (tons of nice wallpapers)
    -(1080p) LCD Density 240
    -(480p) fast as hell;p for thous that dont need hd
    -added Android Tuner
    -build.prop tweaks (wi-fi, ui, and other tweaks)
    -es explorer (manage your files with best file manager, auto apk install)
    -deleted useless aps
    -fixess i dont remember;p
    -modules loaded at startup:
    Code:
        btusb.ko
        xpad.ko
        md4.ko
        cifs.ko
        rtl8711.ko
        nls_utf8.ko
        tun.ko
        ath3k.ko
        hci_vhci.ko
        bfusb.ko
        bcm203x.ko
        btmrvl.ko
        btmrvl_sdio.ko
        ath.ko
        plusb.ko
        pl2303.ko
        gspca_main.ko
        gspca_sonixj.ko
        sunrpc.ko
        auth_rpcgss.ko
        lockd.ko
        r8712u.ko
        fakeinput.ko
        mcs7830.ko
        rt5370sta.ko
        rtl8192cu.ko
        cp210x.ko
        ftdi_sio.ko
        nfs.ko
        ntfs.ko
        virtual_touchscreen.ntts.ko
    install:
    -unpack arhive (anywhere)
    -start RKBatchTool.exe
    -put mk808 into flash mode (pres hiden buton and conect mk808 to pc, use usb otg port)
    -instal proper drivers when windows ask (drivers are in \Rockchip_Batch_Tool_v1.5\Rockchip_Batch_Tool_v1.5 \RockusbDriver)
    -when you wil see number 1 in green box selec "..." button in right top corner of RKBatchTool
    -navigate to MK808 Hybryd FW V2.1.2.img
    -pres restore button in RKBatchTool
    after instal:
    thats the things to do aftrer yoy install your rom o mk808.
    -first bootup will be slower then the next one (android is setting ui)
    -after boot wait about 3-5 minutes and reboot the device
    -go to settings>developer options:
    -change all animations to 0.5x
    Thanks to:
    -2dark4u
    -finless bob
    -kizs
    -minix
    Everything is possible if we work together!
    ApkFreak
    Website down
      Thank you!
      Graet new options:
      Lewy2041 Hybryd FW 2.2.0
      changelog:
      V2.2.0
      Good Work!
        New ver. of Youtube for Google TV 1.6 in first post.
        Fixes youtube ui buttons.
        ApkFreak
          new ver in next week:
          changelog:
          V2.2.2
          -better performance
          -faster boot up
          -tv launcher
          -build.prop fixes
          -screen auto scale to 100%
          what you woud like me to add in next ver?
          feedback wanted
          ApkFreak
            changelog:
            V2.2.2
            -better performance
            -faster boot up
            -tv launcher
            -build.prop fixes
            feedback wanted
            Could yu make a cwm install version ? How does it work the wifi fix ?
              cwm install would be great
              Rockchip RK3066: Imito MX2 & minix neo x5
              Amlogic 8726-M6: Tronsmart Prometheus
              Android Tablet Archos titanium 10.1"
              Windows Tablet Pipo W1
                there will be cwm ver to
                ApkFreak
                  hey men great news, supper
                    Great!
                    Great to see more custom ROMs for X5. Will there be 1080p version ?
                      yes. but only if i get feedback that its working fine.
                      ApkFreak
                        Hi Lewy great ROM been using v2.2.0 on MINIX g4 since you posted it so I tried v2.2.2 but when it finishes booting up the desktop is oversized for my screen, I can adjust it to fit to screen but on reboot its oversized again I can see it upscale when booting also I think the DPI is set to 100 this too small for me but easy to fix myself, gone back to v2.2.0 for now as this is still one of the best ROMs for the g4...
                        Thank for this rom
                          have you already make any progress with the cwm install????
                            Thank for this rom
                            thanks for info.
                            i will check it and fix the problem as soon as i can.
                            as of cwm. not yet. i need more time:"
                            ApkFreak
                              Lewy, this is why you cant set scaling like that. Some TV cant handle 100% and because now you have "set it" the user settings of scaling wont hold on reboot.
