VIDEO DISK RECORDER ( VDR ) FOR ANDROID (RK3288 AND AMLOGIC s805 s802 s812 (KERNEL 3.10.33 ALL DEVICE) )
    no port vdr to android. We used armhf library lubuntu. compiled by user dados
    only problem osd not work. need edit boot init.rc for usr/share folder. at this time cant scan because osd not works on android.
    vdr http://www14.zippyshare.com/v/UGQ9sK2V/file.html
    copy and paste with esexplorer.
    for channels.conf http://channelpedia.yavdr.com/gen/index.html
    downloads your satelite channels.conf
    copy to /data/vdr/config
    init.d script
    Code:
    #!/system/bin/sh
    # insmod your DVB-Modules here
    #!/system/bin/sh
    while [ ""`getprop dev.bootcomplete` != "1" ] ; do sleep 1; done
    insmod /system/lib/modules/dvb-pll.ko
    insmod /system/lib/modules/dvb-usb.ko force_pid_filter_usage=1
    insmod /system/lib/modules/ds3000.ko
    insmod /system/lib/modules/ds3103.ko
    insmod /system/lib/modules/ts2020.ko
    insmod /system/lib/modules/ts2022.ko
    insmod /system/lib/modules/m88rs2000.ko
    insmod /system/lib/modules/dvb-usb-dw2102.ko
    /data/oscam/oscam-1.20 -b -c /data/config
    if [ ! -d /dev/dvb/adapter0 ];then
        mkdir -p /dev/dvb/adapter0
        ln -s /dev/dvb0.demux0 /dev/dvb/adapter0/demux0
        ln -s /dev/dvb0.dvr0 /dev/dvb/adapter0/dvr0
        ln -s /dev/dvb0.frontend0 /dev/dvb/adapter0/frontend0
        if [ -e /dev/dvb0.demux1 ];then
        mkdir -p /dev/dvb/adapter1
            ln -s /dev/dvb0.demux1 /dev/dvb/adapter1/demux0
            ln -s /dev/dvb0.dvr1 /dev/dvb/adapter1/dvr0
            ln -s /dev/dvb0.frontend1 /dev/dvb/adapter1/frontend0
        fi
        chmod 666 /dev/dvb0.*
    fi
    if [ ! -e /lib/ld-linux-armhf.so.3 ];then
        mount -o remount,rw / /
        mkdir /lib
        ln -s /data/vdr/lib/ld-linux-armhf.so.3 /lib/ld-linux-armhf.so.3
        mount -o remount,ro / /
    fi
    ./data/vdr/bin/vdr -L /data/vdr/plugin -c /data/vdr/config -r /data/vdr/res -v /data/vdr/video -P vnsiserver -P dvbhddevice -P dvbsddevice -P wirbelscan -P svdrpdemo -P svcsvr -P svccli -P streamdev-server -P streamdev-client -P status -P quickepgsearch -P live -P epgtableid0 -P epgsearchonly -P epgsearch -P  dvbsddevice -P dvbhddevice -P conflictcheckonly --cachedir=/data/vdr/cache
    Did you make some additional changes?
    My dvb-c card works with your kernel and tvheadend, but it stutters a lot.
    I got w_scan running on my box, but your vdr gives me segmentation faults.
    Any hints?
    btw: I added the LD_LIBRARY_PATH and added some missing libraries
      thanks for share
        try this script kms. I can use but dont scan
        Code:
        #!/system/bin/sh
        #!/system/bin/sh
            fi
        fi
            mkdir /lib
        fi
        ./data/vdr/bin/vdr -L /data/vdr/plugin -c /data/vdr/config -r /data/vdr/res -v /data/vdr/video -P vnsiserver -P dvbapi -P wirbelscan --cachedir=/data/vdr/cache
          Thanks taki for your support.
          I don't know why, but vdr always gives me segmentation faults if I attempt to start it with plugins. It starts without plugins though. No traces in the logfiles unfortunately.
          btw: I think you are using the wrong parameter for the resource directory. It should read --resdir=/data/vdr/res
            hi taki
            any apdate for minix x7 ?
              First I dont compiled vdr. User dados compiled and shared me. This vdr works dvb api 5.10 of device. Rk3188 uses 5.3 dvb api. Need to recompile rk3188
              Second
              I try to compile viciga c90 kernel include dvbsky and dvb api but a lot of error I have but I can fix
                waiting ...
                  Thank for sharing! https://techbigs.com/kinemaster.html
