I noticed a few people mentioning this same problem which I'm experiencing. I can power it off but the blue led light remains on and then I can't turn it back on with the remote. I have to do a hard reboot to get it working over and over again.
I asked the factory for a new firmware which they provided but it's also having the exact same issues. They have no other solutions.
Does anyone recommend a firmware which works perfectly with the remote equipped with the unit? If it has mbox, even better but not too concerned about the launcher at this point, I just want the unit to function as is should.
Thank!
