New in this release:
- Fixed the no signal on HDMI issues (thanks to jim1985)
- Fixed an issue when GUI is slow during a video playback
- Other bug fixes and enhancements
To install OpenELEC to WeTek Play you don't need to overwrite your Android installation. Just write OpenELEC to an SD-card, and enjoy both of the worlds at the same time with dual boot.
Downloads
SD-card image for new installations:
OpenELEC 5.0.7 .img file for fresh installation on microSD card
To install, unzip the provided archive and use a tool, such as Win32DiskImager ( http://sourceforge.net/projects/win32diskimager/) to create a bootable SD-card. Turn off your WeTek Play, insert the SD-card, turn on the box again and enjoy OpenELEC. If you want to boot Android, just turn off the box, eject SD-card, turn on the box again, and you'll see Android booting.
Or you can use WeTek OpenELEC Installer app, which will download latest OpenELEC release and burn it to MicroSD:
WeTek OpenELEC Installer application
For updating the existing SD-card installations (Do not use this for updating NAND installations!!!):
OpenELEC 5.0.7 .tar file for updating existing installation on microSD Card
BACKUP YOUR DATA BEFORE UPDATING!!!
You can read about how to update an existing OpenELEC installation at http://wiki.openelec.tv/index.php?ti...ating_OpenELEC
Now you can also install OpenELEC instead of Android into NAND memory.
Image for for new installations into NAND memory:
OpenELEC 5.0.7 .zip file for installation to NAND Flash
Just unpack the provided ZIP archive onto SD-card, insert it into the box, and enter recovery using toothpick. Installation should start automatically.
For updating the existing NAND installations (Do not use this for updating SD-card installations!!!):
OpenELEC 5.0.7 .tar file for update of existing installation in NAND Flash
