Need help installing Google Play Store
    Greetings.
    Have a MIC MT6752 that doesn't come with Play Store installed. It is also not rooted.
    Appreciate any advice on installing it, without rooting the phone if possible. OS is 4.4.4.
    Many thanks and best regards.
    First go into settings, security and tick "Unknown Sources".
    Then download play store app http://forum.xda-developers.com/show....php?t=1996995
    Wait until it has downloaded, tap the notification and select install.
      Greetings Colin. Thanks for the kind reply.
      1. Is root access required?
      2. The device also lacks Framework Services and one or two other pieces of supporting files. How to install these?
        You don't need root to install an app.
        I'm afraid I cant help you with the second question. I don't know.
          Thanks for the kind reply, Colin.
          Anyone else?
            I'm afraid you will need to root your device. That is how I did it. Once rooted you copy the files to the /system/app folder. Then you have to set the necessary permissions on those files and finally reboot. Hopefully if all goes to plan you should see the play store icon.
              Thanks for the kind reply, Indy.
              1. What are the files required?
              2.Can the apks be installed rather than being copied over? What's the difference?
