Cube Talk 9X U65GT MTK6592 32g V2.0 2015
    Hello MTK users....
    I have a Cube Talk 9X U65GT MTK6592 MT8392 32g V2.0 20150114 1450xxxxxx
    Rooted/Chinese removal with system boot/recovery on; fairly ezy. All I'd like now is to partion space (10-16gs).
    I have tried the spflashtool. This will not find my device. The tab always recharges when hooked up to pc when tab power is off. PC only sees tab when tab is turned (power) on. I've updated the drivers and all. Any ideas to flash? Checked all system settings. Tab only charge mode when power off. PC does not locate/ find. Am I missing something?
    I see that 900Supersport Quotes
    "CWM zip for 6 Gig apps space
    PS Lepi pointed out to me that its easy to boot into recovery as follows. First power off the U65GT, it vibrates when shut down completes. Press and hold power for about a second then press and hold vol+ until a menu displays (its small in white). Scroll through the menu options with vol+ and select with vol-"
    Does this mean that I can system boot/recovery on tab this zip file after renaming it update?
    Then format, reinstall all backups all from the tab?
    Thank you in advance for any/all your help!
    TexBud
    Edit: power on connected to PC; android ask what type of device ie. storage, phone, media, charge mode. Also an android permission window to allow connection between tablet/PC.
    Power off these must default to charge only mode. Any thoughts.....my stock ROM?
    Here is my topic where I have the same problem....
    What I did - I enabled USB debugging in the development option tab under the settings....
    Then I can MTK discover the device but ony when it is powered on normally....
    I'm little bit worried to go forward even when rooted as I don't want this device to be transformed into the "brick" if something goes wrong.... And yes all I want is to repartition device...
      Thank you for your reply.
      I already had/USB debugging enabled. I getting to believe that because of the 2 andriod windows described above has something to do with my/our problem. It's NOT just connect tab to PC. Two other steps need to be completed before PC/tab hookup!
        I retried again. I did a total data/cashe and a factory reset. I still do not get the red bar on SPflashTool. It can not even find my tab/phone. The tab/phone in about 1 min shows battery charging.
        I get 2 windows on tablet. 1) Android USB mass storage. This window allows to connect or disconnect tab to PC. 2) USB computer connection. This window there is 5 choices; 1) USB storage 2) Media device(MTP) 3) Camera (PTP) 4) Charge only 5) Built-in CD-ROM.
          I did it!!!! increased to 16gs I had to uninstall drivers then reinstall correct drivers...I found this info in the STICKY section in MTK tablets.
          Thank you all here at FREAK TAB!!!
          TexBud
