Play Store- No connection?
    Hey Freaktabforum,
    I am running Finless 1.7 on the Mk808B Orig. and everything works great but the Play Store. 2 Days ago it stopped working, every time i open it i says no connection. I know what you think:Wifi Problem.
    but no, i can use other apps that need internet but the play store does not work. also installing the new Play Store version 3.10.14 did not fix this.
    Any Ideas? thank you very much!
    And Finless Bob, you sir, rock !
    Originally posted by thepiet View Post
    Hey Freaktabforum,
    Clear the Market data and cache?
    Might be worth deleting your Google Account, going into Google Play Store and setting it up again that way.
    Currently Using:
    2 x Nvidia Shield TV | MiniMX III
    Retired Devices:
    MiniMX III-II | Mk808b Pro | Mk808b Plus | Raspberry Pi 1 + 2 | UBOX R89 | MK808 | MK808b | CS008 | X1 4K (rk3288_809) | CYX_809III | Ouya | CX-919 | S82 Plus | Tronstmart R68
      Set correct date and time it did the trick for me
        thank you very much
        I don´t know why but setting the time & date manually seems to work...strange bug
        thank you !
          thank you !
          I 've been having the same problem with all the roms stock and finles and could not find the fix. I couldn't believe my eyes when i did it. Thanks
            This isn't a bug per se... it is by design. The Play Store ( and many other websites / programs ) use the date and time in order to work properly... on Windows, the updates won't work properly unless the date/time are relatively correct. If they had not been programmed to work that way, then you could call it a bug... but as it is, it was programmed like that so it is by design.
