What rom can i install on rikomagic IIIS?
    I tried to install Finless 1.8 but there is no WIFI and Bluetooth.
    what other rom can work on this device?
    AW: What rom can i install on rikomagic IIIS?
    in the download sektion is a Rom for your Device. Take a look there please.
    Neomode FreakTab.com Developer
      Re: What rom can i install on rikomagic IIIS?
      Neomode made a great custom rom too. You can see it:
      My devices:
      Gearbest.com)
        i installed this rom and there is no space to download apps,photos or anything.
        how i fix that?
          how i fix that?
          I assume you have the 4gb version so only 1,75gb approx to internal storage free, you can use a external microsd like most of people does. Its better use internal nand to store the apks installed, and keep the music, photos, video, etc... In the microsd, but if you dont want to use a microsd, you need a new parameters file, we can ask neomode to make one for you.
          My devices:
          Gearbest.com)
            i have the 8gb version , i just cant download anything from web. even a picture ..
            when i was on stock rom i didnt have any problems with downloading files.
              Ok then you have your sdcard unmounted or corrupted, please can you tell me what says in /settings/storage/ ?
              My devices:
              Gearbest.com)
                Internal Storage
                total space: 1.23GB
                Apps 337MB
                Available: 798MB
                NAND FLASH
                Total Space: 5.05GB
                apps: 1.82MB
                misc : 500KB
                available: 5.05GB
                i think its working now ..
                but why 5GB is for NAND? its not too much?
                  no but you can change it with a reflash.
                  I can gave you a parameter file for up to 6 GB App Space
                  Neomode
                    another problem , i have external usb connected (8 GB sandisk) and sometimes i get message that the external storage is not connected.
                    there is no problem with my dok...
                      This can be a Problem of your Power Supply.
                      How many Ampers have it ?
                      Neomode
                        tried it while it was connected to my computer , and tried it when it was connected to the tv usb.
                        yesterday i had no problems with that.
                          Some hubs dont works very well, I bet for power supply problem like neomode says or hub if you use it.
                          My devices:
                          Gearbest.com)
                            As far as i know the official specs for an USB port is a max of 500mA. So connecting it to a PC or TV USB port might work and clearly a lot of PC/TV USB ports will deliver more then 500mA, but i assume most PC/TV USB ports wont come close to 2A.
                            - UG007-II with Finless iMito MX1/2 1.7a ROM and UG802 2Dark4U 1080p overclock kernel and USB WIFI dongle.
                            - MK808 with Finless MK808 1.7c ROM and 2Dark4U 1.4 MK808 1080p overclock kernel.
                            - MK908-II: XBMC full 1080p playback with a 1080p kernel HERE
                              Agree, 500mA is low to feed the stick.
                              My devices:
                              Gearbest.com)
