M8 wake up issue when using WIFI temp solution
As most of you know there are so many Excellent ROMs out there that got spoiled by the fact the M8 freezes after waking up from sleep when using wifi. In my case it gets sluggish and then reboots and hangs there until i unplug and plug back the power. i just realized that there is a simple workaround for this issue. I turn off the wifi before i put the box into standby mode. When i turn it back on i manually turn the wifi on. Doing this solved this issue for me. I just wish if someone can write a script to automate this process.Tags: None
There are currently 1116 users online. 2 members and 1114 guests.
