MK802III with Ug802 1.8 Rom issues
    Hi bob and all others,
    i'm using and testing hard the ug802 1.8 on my mk but I do have issues that I didn't had before with 2dark4you 1.7 over locked version of yours
    the issues:
    1- cant use my ps3 gasia wireless remote like before using six axis or bt/USB joystick app
    2- wireless goes off every time I reboot
    3- the status bar hide auto or not is not functioning ok with xbmc
    4- sites with flash hang have to rreboot
    can you please confirm any of them
    best regards
    I help with 4GD663269M466950W
    And you ????
    My devices:
    Tronsmart T428 real 3188 with Finless A928 and D33 Kernel at 720p
    Tronsmart Prometheus won on CNX just now....
    Can someone verify the info that i put on the thread please.
    I ewnt back to the 2dark4you rom version 1.7 all fine now.
    And you ????
    My devices:
      the issues:
      best regards
      I have MK802III with Finless ROM 1.8 too.
      2- wi-fi is still on, no problem
      3- autohide status bar works fine with every app and xbmc too
        Originally posted by Wolfsteen View Post
        Maybe with more free time i will try a new rom burn on my stick
        Btw every time i do a rom upgrade i erase the nand flash, is there anything more that is advised to do, just to start with a full clean stick before upgrade the rom.
        Best regards
        And you ????
        My devices:
          Well folks i give a it a new try on the 1.8 ug802 rom by Finless and now more happier with the result.
          Also i have now a full 3A 5V AC-DC power suplly that has been doing magic arround here.
          Only one issue i can't use the app USB/BT to connect my PS/3 compatible controller, it simple doesn't see any usb device connected but doing dmesg it's there connected.
          This worked fine on the 1.7 Finless/2Dark4you rom.
          anyone....
          And you ????
          My devices:
