Overheating? Throttling? Something the Z64 never heard about :)
RK3288 Devices
- Overview BOX (LINK !)
Fly Mouse Mini Wireless Keyboard with 2 mode learning IR remote 'iPazzPort KP-810-16'Tags: None
Pfff...
My cheap Pipo X7 with cheap and simple mod for 10$ (simple work for 10 minutes, my grandma can do that). Room temperature is 24 ºC.
Max temp is 14 ºC lower than Z64.
"I am watching you pretty boy..."
Do you need real burn-in test? Run LinX (CPU burn test) and MSI Kombustor (GPU burn test; Burn-In DX11) at same time. At check you clock when Z64 will go down (throttling), I promise you will not wait too long.Last edited by no_spam_for_me; 14 April 2015, 17:20.
Pfff...
1. but you have to do the mod which not every one is able to do
2. no need to post these kind of (adult) pictures ! LAST WARNINGRK3288 Devices
hmmm, these results are definitely objective, but maybe you would like to explain the situation where you have the overheating / throttling?
RK3288 Devices
Originally posted by Kyrie View PostPfff...
Do you need real burn-in test? Run LinX (CPU burn test) and MSI Kombustor (GPU burn test; Burn-In DX11) at same time. At check you clock when Z64 will go down (throttling), I promise you will not wait too long.Originally posted by Kyrie View PostOK, I have got cheap thermal pad (5 mm) and waiting for heatsink.
Thermal pad at bottom side is fantastic!
Without thermal pad normal temperature was about 60 °C. LinX (Linpack, best CPU burn software) warmed up SoC up to 86 °C (trottling) in 1 min 30 sec.
With thermal pad normal temperature is about 50 °C. LinX needs 15 min 25 sec to burn (up to trottling) SoC!
AIDA and software 1080p decoding can not warm up CPU anymore.
Monitoring: AIDA64 Engineer v5.20.3400
LinX 0.6.5 http://www.heise.de/download/linx-1192687.html
=> NO throttling/overheat after ~ 30 minutes
MSI Kombustor 2.5.9 (32bit) http://www.geeks3d.com/20140917/msi-...ncl-benchmark/
(GPU burn test -> Direct3D 11)
LinX 0.6.5 and MSI Kombustor 2.5.9 (32bit)
=> begins to throttle/overheat after ~ 17 minutes
Conclusion: Out of the box without any mod -> really nice
RK3288 Devices
Originally posted by alwaysbless View PostMy Z64 overheats / thorttles all the time O.o so looks like results are subjective. With mods on my x7 my temps are easily 10 degress less under load (those vent holes and aluminium casing def help)
I watched a teardown of this device, can everyone check to see if the manufacturer used a thermal pad? In the video the CPU die and heatsink were both clean.
Simply adding some thermal paste could drop it 15 degrees.
Any link?RK3288 Devices
There are currently 1839 users online. 0 members and 1839 guests.
