Two different mk806, one finless rom?
    Were not able to find an answer for my request on the forum, so just opened a thread about it.
    I have the latest mk806/mp802 model available with earphone plug and BT:
    I also have the "other" new mk806 model without BT:
    In the first case or the other, I wonder if there is a finless rom available for that.
    For the 1st mk806, a rom that kept the 3,5mm audio output and the mic in.
    For the second stick, I suppose there is one rom available, but I wonder if someone here knows which rom (according to the wifi chipset)?
    Thanks for any help provided!
    Neomod has been kind enough to work on the audio model. You can follow his work here:
    http://www.freaktab.com/showthread.php?2829-Mk806-OG-rom-audio-woes&p=63450
    Any other info for the other model will be appreciated. Thx
      Here are some pics of the inside of second mk806 model in the hope someone guide me in the choice of the appropirate rom since I am totally noob in this
ID:	430057Click image for larger version
