Help!!! Internal storage problem
    My device: Measy B4A (round) and i have problem with internal storage.
    I dont know how go wrong but when open settings/storage this i see just 1 second: (sorry slovak language)
    and then:
    Please can you help me how to fix storage?
    And now while booting device shut down! But when going to recovery and reboot device start normaly.
    thanks
    Nobody can help me with my issues?
      so I tried some commands at the terminal:
      su
      cat /proc/mtd
      and
      cat /proc/partitions
      i see zram0 and mtdblock0 and mtdblock1 ........ ok i search somethings on google what is zram0 and try it off:
      then:
      free
      swapoff zram
      but swapoff dont work or how save swapoff result?
        who can help me please
          What you are seeing is normal behaviour for Android.
          Why do you Want to turn off the swap file? This is needed for speedy operations.
          The command is working fine in your screenshot. First shot shows 512000 as size, and second shows 0 as size. You turned off the swap file. But why?
          Everything is normal. No reason to get exited. Do not turn off the swapfile, it's swapping on ram.
          The reason you see the unallocated / defined screen for one second, is that Android is calculating the useage of data by apps, video, pics etc. and then applying the color bar to it.
          In both screens it shows you have 3.97GB free, which is correct. The internal storage is also used by the android OS and takes up some space. It is normal, and you will not have the entire 8GB to play around with.
          It is possible to damage sh1t when you play around in the command line with commands you do not understand. Be carefull and do not do things you are not 101% sure of what they do.
            Hi Asure Problem is with internal storage. I have now 5.34GB and not 8GB How repair it?
              [ATTACH=CONFIG]temp_10026_1430508932486_337[/ATTACH]
              NEWSFLASH This just in.... That "missing" 2.66GB's of Storage? Its your Android OS! Or did you think that they held this on its own Storage?
              And, before you even go there... EVERYONE DOES THIS, even Apple! Your Device has exactly 8GBs of storage, by proxy of having exactly 5.34GB Free....
