accelerated video / video processor (VPU) running on linux on RK3288 / firefly
Originally posted by youbainiao View Posthi MAC_L1,where can I download you use android SDK,I use rk3288_r-box_android4.4.2_sdk(firefly) and replace the lib in /system/lib,but not normal.
I use the same SDK from firefly. But it needs to be patched quite a bit to get libhybris working. To get some feeling: http://linux-rockchip.info/mw/index.php?title=LibHybris for RK3188; for RK3288 other, similar patches are needed. And for libmedia support even more patches needed.Support my work to make you a better multimedia experience...
And Donate...
Originally posted by youbainiao View PostSupport android5.1?
Will make new 5.1 version based on radxa rock2 5.1 SDK if this one support 1080p or higher.Support my work to make you a better multimedia experience...
And Donate...
hi MAC_L1,I follow the instructions: http://wiki.t-firefly.com/index.php/...droid/en,check out source via:
tar xf /path/to/firefly-rk3288_android4.4_git_20141211.tar.gz
git reset --hard
git remote add bitbucket https://bitbucket.org/T-Firefly/firefly-rk3288.git
git pull bitbucket master:master
than
cd bionic wget http://wklej.org/id/1308620/dl/ -O bionic_libhybris.patch
patch -p1 < bionic_libhybris.patch
mkdir libc/hybris
wget http://wklej.org/id/1308661/dl -O libc/hybris/libdsyscalls.c
remove libdsyscalls.c first line
cd firefly-rk3288/kernel
make firefly-rk3288_defconfig
make -j8 firefly-rk3288.img
cd sdk
make -j8
cp out/target/product/rk3288/system/lib/* to my board,run test,but glCompileShader fail,I do not know what is missing.
can you give me the download link you use firefly android4.4.2?Last edited by youbainiao; 17 November 2015, 09:57.
hi youbainiau,
please look at one of my first posts in this thread, to memeka: http://freaktab.com/forum/tv-player-...738#post498738, post #23, and the attachments i added to it
it is not enough to copy only the .so files, but you also need to mount the whole system.img generated by building patched android to /system
you can strip it later when fine-tuning.Support my work to make you a better multimedia experience...
And Donate...
hi,MAC_L1, Now I have encountered a new problem, with your hybris library to achieve the call OpenGL function, when I'm on the side to download and draw(Multi thread is obvious), I found that swap buffer of OpenGL will affect the download failed, I'm not sure where there are conflicts caused by.
Hello
I will help you bring it to an end.
I got back here and I see that since then nothing has changed.
My answer is the start of sdl2 attempt, in 2013, sdl2 + gave me a little smoother HD playback.
and CPU consumption of only 10% that is the problerm with X11 and the lack of software for the VPU.
In 2013, we did a kernel module for HW acelerating only thing missing is support from the VLC, MPlayer and the like.
look-please-*this:
http://freaktab.com/forum/tv-player-...88_vpu_support
my old account =taki-arm
http://freaktab.com/forum/tv-player-...ali-3d-support
how I was doing EXPERYMENT with video + driver 'mall' is not understood community of developers that this is time related.
sdl2 itself gives full hd indirectly, without the aid of x11
the problem lies in the x11 server does not provide what can the program.
x11 blocking what we can achieve.
The Ubuntu community because she wanted a new graphical server xMIR which will be not dependent on the old dependence.
and what we have today, nothing, we are in the shit.
So do not be afraid and knock out of this shit, and let us all or VPU support.
And who was that I wanted the '
we all live under the pressure of a prohibited cod and so really the prohibited uses of our codeLast edited by arcade; 03 December 2015, 02:52.
Hello,
I am sorry to open this old topic, but I would like to get the encoder on RK3288 working. I already got it working with gstreamer-rochchip (https://github.com/rockchip-linux/gstreamer-rockchip) libraries, but the encoded video has really high bitrate and I need the bitrate to be lower. For example source video bitrate is 2Mbps, but the encoded video bitrate is 12Mbps and the video quality is very similar. What is the lowest bitrate that is possible to encode with machybris? I installed machybris through the install script, but when I run test_vpu as decoder with h264 stream on input I got error "init vpu api context fail, ret: 0xFFFFFC16" and error code -105. How can I get it working?
Thank you
There are currently 3664 users online. 0 members and 3664 guests.
