Cube Talk 9X problem pairing Bluetooth
Does anyone have a problem pairing Bluetooth devices? In the bluetooth settings I can see all my bluetooth devices i.e. speaker and successfully pair it (it is shown paired) but none is working. I've just bought U65GT and updated to the latest firmware v2.0_20150409.Tags: None
What kind of bluetooth devices you have? There are different bluetooth connections and I guess that Cube Talk 9X doesn't support them all. For example new smartwatch uses often bluetooth BLE connection and I think that Talk 9X doesn't support it. But standart wireless headphones should work well. Maybe you have to try wiping cache and dalvik cache and then factory reset.
My bluetooth devices are Mi Band, Sardine SDY019 and Bluedio BS-2 speaker. Both SDY019 and BS-2 have no issue pairing with my iPad2.(Mi Band requires BLE). I downloaded an app named BLE Checker and it says that Talk 9X is BLE Supported. I tried wiping cache and factory reset as you suggested but the issue still persisted, as for the dalvik cache I don't know how to delete it, perhaps I have not rooted my device? Does it have something to do with the firmware I upgraded?
Originally posted by naronga View PostMy bluetooth devices are Mi Band, Sardine SDY019 and Bluedio BS-2 speaker. Both SDY019 and BS-2 have no issue pairing with my iPad2.(Mi Band requires BLE). I downloaded an app named BLE Checker and it says that Talk 9X is BLE Supported. I tried wiping cache and factory reset as you suggested but the issue still persisted, as for the dalvik cache I don't know how to delete it, perhaps I have not rooted my device? Does it have something to do with the firmware I upgraded?
And yes you need to be rooted with custom recovery to wipe dalvik cache but I don't think it will help anymore.
EDIT: Have checked the "Media audio" option in bluetooth settings?
There are currently 2584 users online. 1 members and 2583 guests.
