Eny M8S WiFi not turning on?
    I have the M8S and have been having an issue where the WiFi is not turning on. It just stays at Turning WiFi on under the settings page or Refresh Access Point Lists on the main settings page. I have updated to the Feb 11 2015 firmware with not luck.
    I have also had an issue with slower then normal network speeds. My home gets 45mbps but the box is only pulling around 10mbps.
    Any one else having these issues or can suggest some other things to try?
    can you link me up with the firmware so I can have look at it for you ?
    Bugs are Sons of Glitches!
    JustMe
      This is the firmware I tried last.
      I also tried the Jan and Dec firmware mentioned in.
      http://freaktab.com/forum/tv-player-...812-square-box
        Got issues too with my WIFI, i installed the firmware made by Stane and it's fine now.
          Did you ever manage to get the WIFI working again?
          I have the same issue.
          Tried all firmwares without any luck.
