Can any one please explain the MTD blocks solution in more detail ?
Dual kernel choice at boot time
Originally posted by leolas View PostNot exactly the same, picuntu flash a kernel with a initramfs, dont know exactly what is in this, cause I started with picuntu 2 days ago, if you flash a kernel alone picuntu don't works.
RK chips boot like this.
1) If kernel is in boot.img then on boot it will use kernel from boot.img.
2) If kernel is not in boot.img then it will boot and use kernel.img
3) If kernel is in recovery.img then boot to recovery will use kernel in recovery.img
4) If kernel is not in recovery.img (like CWM does it) then it will boot to recovery and use kernel.img
Re: Dual kernel choice at boot time
Originally posted by Finless View PostGood point! So if we have a boot.img with kernel in it, it will have initramfs. Thus theoretically you could flash this boot.img to recovery space and it should boot.
This devices are really fun and great to learn.REMEMBER, YOUR FEEDBACK IS VERY IMPORTANT TO US.My devices:
It worked , (only with the stock firmware) , what i did is:
1-Flashed stock rom (720p version) for imito mx1.
2-Flashed stock boot 1080p version into the recovery space.
3-The 720p version can be accessed from normal rebooting or unplug/replug the usb cable
While the 1080p version can be accessed by rebooting to recovery.
As i mentioned before this solution worked only with stock firmware , unfortunately not with
Finless 1.7 or 1.5 firmwares , i am suspecting that it has something to do with partition sizes
Which is changed in finless roms to give you more app space (not sure of course if this is the reason)
I would consider this a perfect solution if it worked with finless rom.
Any sugesstions or ideas To make this work with finless rom will be really appreciated.Last edited by opengl1971; 03 May 2013, 06:49. Reason: Step 2 wasn't right , stock boot need to be used
I am pretty sure it is because the stock ROM has a kernel and ramdisk in boot.img and my ROM does not. I take it out of boot.img so people can use other kernels easily. So that is probably why.
When I get some time I am sure I can make a dual boot for you guys with my ROM.
Thanks bob for the explanation , i can verify what you said my self , because i tried with cwm
I made 2 system backups for 1080p and 720p of you rom then i needed to restore both
The kernel and the boot to make the resolution change , but when i did the same with the Stock rom i only needed to restore the boot to do the resolution change.
It will be really great bob if you do a dual boot for us , we got used to your roms so much that
Using the stock rom is like going to stone age , thanks again.
Originally posted by opengl1971 View PostA little update:
When rebooting to recovery to access 1080p mode
When in 1080p mode the internal nand storage shows up as corrupted although it isn't
When rebooting normally to the 720p mode the nand storage shows up as working correctly.REMEMBER, YOUR FEEDBACK IS VERY IMPORTANT TO US.My devices:
Originally posted by leolas View PostYes, seems that you need a boot.img with kernel inside to make posibble the dual boot.
If the kernel is needed to access the internal sd shouldn't The external sd and usb storage
Be inaccessible too ?
Originally posted by opengl1971 View PostThanks leolas for the reply , it works ok and boots at 1080p and everything works except the Apps that depend on the internal sd to work , what i don't understand is why the external sd And usb storage work While only the internal sd doesn't work ?
A kernel.img alone?
Ok, now I see you installed the stock boot.img with the kernel inside. We need to compare both boot.img to see what is the problem. I am ending with a WiFi dongle problem that I had, and helping a guy to make it work. If I get some free time I will try to do this.REMEMBER, YOUR FEEDBACK IS VERY IMPORTANT TO US.My devices:
Sorry, i am playing with the new kernel sources and learning some about modding. I will try with it when I have some time.REMEMBER, YOUR FEEDBACK IS VERY IMPORTANT TO US.My devices:
There are currently 2817 users online. 0 members and 2817 guests.
