so the problem i had is with this android tv box.
from the beginning the box works not good.... apps are closing automatically after starting... the box freezes and shut down.... go into a bootloop... and so on and on and on......
so what can i do... what custom firmware can i take to make this box usually??
this is the box
http://m.****.de/itm/301315682751?nav=SEARCHif
the chip inside of the box it says rk616
please help.
