Hello friends , I have a tablet that was stuck in a boot image I tried to order reset without success, I decided to look for a consistent original purpose or firmware , without success , in this case , I saw that part of sacrifice you could , I would help already downloaded About 500 Roma to RK2928g goal only has less ran the beat on the screen does not respond. Polaroid Modelo MIDC410PR009 CPU: RK2928g placa: R108 130 325 VER0.2 - CHIPTRIP Including already tested several standard Rockchip RK 2928g firmware but without success. Only 3 of them work fot almost everything , like camera , wifi, etc ... but touch does not respond and rotation appears to hang . Works 90 % - TP105C rk2928 20130506 - Globex-GU110A_GU110A130001-GU110A133500 Thanks in advance !!!
Polaroid, MIDC410PR009.112
Tags: None
This is a buckup of the same device, just flash it using android tool
Oops, rapaiz you will save a homeland !!! I'll be waiting , and tells me how this restoration will be done . Because I have done the installation of CWM and it worked perfect, minus the TWRP cuz because of touch, but the CWM works well. I thank you !!! Once you are with the available link, to install and put the result. hugs !!!!
Originally posted by moha pidro View PostThis is a buckup of the same device, just flash it using android tool
http://www.mediafire.com/download/7y...r_Polaroid.rarLast edited by castagnazzi; 27 April 2015, 22:46. Reason: Next friend, used the tool RKAndroidTool and everything worked . Congratulations attention and effort. God bless him !!!
Here is the tool: http://www.mediafire.com/download/xa...dTool+v2.1.rar
download it then extract it and follow these steps
1. Run AndroidTool.exe as administrator
2. Click on the empty case next to parameter
3. Navigate toward the firmware you downloaded and select PARAMETRE.txt
4. Check the box next to Parameter.
5. Do the same to "misc, kernel, boot, recovery, cach, kpanic, system and backup".
6. Connect your device in download mode. The message "No found any devices" shoud become "Found one loader device".
7. Hit "lowerFormat" button when its fonnished formating, hit "Run"
8. When android Tool says "Download image ok" restart your device. If every thing goes well your device shoud work as a charm.
Please tell us if it worked for you.
Originally posted by castagnazzi View PostOk friend , I am grateful for their dedication and atensão , the tablet is already up and running . God bless you !!! Hugs .
"Ok amigo, fico grato por sua dedicação e atensão, o tablet ja esta em perfeito funcionamento. Deus os abençoe!!!
There are currently 1538 users online. 1 members and 1537 guests.
