RK3288 Blitz Brigade Controls Problem
    Hello,
    I have a Bluetimes RK3288 box and i am trying to play Blitz Brigade. The game installs, loads and runs fine my issue is with the controls. I am able to move forward/backwards and sidestep but when i look around i am only able to look up and down i cant look left or right and thus i can not aim.
    Note that my generic PS2 like gamepad works just fine in other similar games like "Dead Trigger" and "Neon Shadow" and i also checked that all my sticks and buttons work with Gamepad tester ( https://play.google.com/store/apps/d....gamepad&hl=en )
    I can also provide you with the keylayout file that i have made for my controller. I assume that the problem lies in the fact that the game supports only the Moga gamepad
    Anything i can do to have full working controls ?
    If the game is only for MOGA there is no much to do. You can try those apps to fake a Moga Controller and se if it helps:
    Or Tincore Keymapper using Mode M to emulate MOGA
      I have tried those programs with little success. but i will give them another go and post back the results thanks
