SP Flash Tools Mediatek Tablet communication problem
    Hi to all, I have 2 tablets one Cube UT65, and one not very popular Prestigio . I am trying 5 days now to make Prestigio tablet to communicate with the PC in preloader mode, I had installed and tried a lot of drivers, and 2 PC's widows 7 and 8 with no luck. I tried to root it no rooting method is working, the most I had done is to partially root it, but I cannot make the /system partition R/W, when I reboot root is gone. Searching the net I had found that is due to boot.img secure=1, using MKT droid tools I made a system backup, I have the recovery and boot image and scatter file for Prestigio tablet. Unpacking the boot.img it is indeed secure=1.
    I had edited all the entries in default.prop, in ramdisk folder, but I cannot upload this boot image in the tablet, all the drivers I have installed are working with my Cube 65GT tablet.
    I have error 2004 as in picture, I had read that this error might be from locked bootloader, I want to ask if anyone knows bootloader is the boot.img? and if yes the preloader state isn't before boot mode? Perhaps a developer as Lepi or Supersport must know.
    Prestigio PMT7177 is MTK8389 SOC tablet 10''
    Has anyone any idea how I will make this Tab work with SP flash tool, without this I cannot flash anything.
    I had similar issues when flashing my cube talk 9x I can't see the screenshot fully but is there a region column. If not there is an issue with scatter try use the stock one and placing it in your flash to blocks folder in mtk droid tools. And making sure all are selecting correct blocks . See my tutorial for further information. Note This might not fix your issue but may give you further ideas.
      No there is not region column, but the strange think is that the scatter I had put was taken by Mtk Droid Tools and must be correct.
        I had an issue with the scatter created my mtk droid tools . So I took one from stock firmware and put it in file to flash folder . Opened that in flash tools then made sure I picked all the locations from the files to flash for each section and recovery as twrp . Things to check when using stock firmware , make sure address are the same and MTK droid tools had no errors when creating backup . This should have come up in right hand window when it was creating file to flash . See my tutorial . Second part I think . http://www.FreakTab.com/showthread.php?t=496463
