I have checked all my drivers and Windows insists they are up to date, though I’m sure how much I trust this. Is there any point in trying to upgrade directly from Intel? Any help would be much appreciated.
HDMI audio not working correctly
I have had nothing but trouble with my Pipo. I want to like it but I just can’t get it to work properly. The latest thing is a problem with the HDMI audio. It is very weak and only present on one channel. Other sources work properly so problem is not with the TV. Audio output through the earphones seems normal, both channels in stereo, equally strong.
Tags: None
I don't think it's a problem with the driver because it's the first time I read about this problem... (if already checked with another HDMI cable and at another TV, then maybe a bad soldering at the device at the HDMI port???)
Because of driver update I use http://www.intel.com/p/en_US/support/detect
because with this tool I get a newer GPU driver than I use this one https://downloadcenter.intel.com/dow...7-8-8-1-32-bit
RK3288 Devices
- Overview BOX (LINK !)
Thanks for the replies. I had already run the Intel update and downloaded the latest driver though that did not seem to make any difference. I have downloaded the Finless pack but not yet installed anything. I am juggling some things at the moment and will get to it when I have time. Unfortunately, I do think this is a hardware fault. Very discouraging since this is a new computer and I bought it from a Chinese supplier, who seems to speak a very unique kind of English, making any communication almost impossible.
There are currently 1517 users online. 1 members and 1516 guests.
