Back of the Pipo X7S:
Notice the extra reset hole and micro USB. On the inside you can find the reset button. The pads for the button are available on the X7, but no button is solderd.
PCB:
Top right you can see the reset button.
PIPO X7S left, PIPO X7 right:
- Left of the screw mount you see the pads for a new (micro) USB connector?
- Right of the screw mount hole you see the new connector.
Unfortunately this last one is not focused.
- They removed the extra - what looked like (unused) ''USB port'' in the X7S and a new connection is introduced like you can see above.
Any specific parts you want to see? let me know!
