These boxes are getting smaller and smaller.
Some Picks to get started with.
Looks good.
Some Coupons for the Bundle Deal 28 July
http://goo.gl/4ISA8C Coupon: OFEFJJOV 32gb version with Airmouse
http://goo.gl/LUcDsJ Coupon: HVJPIXGO 64gb version with Airmouse
http://goo.gl/ZkqHm9
What's in the Box
The Blue ring of confidence = it working, also a small blue LED on front.
Flashed Red during power down etc
Interesting Android, very bright and settings also looks very sharp
Ok whats inside had a feeling looking at the Layout of Connectors and yep the CX-W8 but improved
Bit of a look see underneath heat sink etc
Ram is Samsung
Wifi Module
Ok so there is a start on whats in the box etc.
I like the Blue led on top also Power button easy On and Off, no fiddle switch around the back, Tap once goes to a standby mode both Android and Windows
Small Compact as mentioned like it.
Its been running now for about 35 minutes or so just loading software nothing to heavy as yet.
Temperature is sitting on 45c peaked at 50c while doing stuff so not going over the top, yet will stress it latter and see if it has a melting point.
They say first impression are the best. I like it so far look good and the quick loading of software easy Wi-Fi speed good.
More to come
Cheers
