Hi there ,
I'm using this apk https://play.google.com/store/apps/d...es.yesgo&hl=en which is online tv app.
When running it on HPH V6 (stock firmware) I get error 809 which means that the firmware is cracked and because of copyright violation the app will be closed.
on Minix 8 the app run fine , no error for OS being cracked / not original.
Any idea what is changed from the HPH os to the Minix os ? I really want to make this apk work on HPH V6
Hi ,
My Minix isn't rooted , I've tried installing "Hide My Root" on the HPH and that do "Hide su..." but the response was "unable to hide root".
I'm not sure if HPH is rooted at all.
I'm not sure, because I don't use it, but if I'm not wrong, you can root this fw by a trick via the calculator, so I think there exists some rooting-parts which the app maybe recognises...
I think mo123 can give better support at this problem/situation...
