Dual booting Android and Windows on Minix Z64W
    Boots from USB ... no firmware flashing or BIOS modifications required. All you need to do is download the image from https://drive.google.com/file/d/0B99O3A0dDe67elhnQ2I3aS1QSEU and uncompress it and then write it to a USB using either using 'Win32 Disk Imager' on Windows or using 'dd' on Linux ... see https://youtu.be/6IYZS52400U
    This is my 32-bit compilation of Intel's last Android on Intel Platforms source code explicitly defined for baytrail products (see https://01.org/android-ia). However I've updated the system to include Google Play Store and added root.
    I've also made a video showing a summary of some key information and performance figures including the results from 'About Tablet', CPU-Z, AnTuTu and Octane ... see https://youtu.be/Gfu11EZBD3M
    Note that the initial boot is quite slow. So slow that my video of it is probably the most boring one you could ever watch ... see https://youtu.be/S1qVfsljo2w
    thanks for this. this is an answered prayer for z64w owner who don't want to give up windows for android. gotta try this out later.
      Thank you for the information linuxium!
      I could boot into android, but there is a problem with the audio?
      I couldn't get any sound via HDMI cable on my TV. Using windows, everything is okay.(no sound problem)
      Maybe some audio drivers for 32 bit Android or for HDMI sound interface are missing?
      Did you check the sound?
      moonrise
        Excellent stuff, I'd try it now if I wasn't so tired. Tremendous effort thanks for your time.
          Great. I'm a newbie Z64A owner... Excuse me for my questions...
          How can I have dual boot with Windows and Android?
          And, another question... Do I need a cable USB keyboard installed at boot for selecting O.S. ?
          Thank you in advance
            will wifi work?
