bootanimation on finless 1.7c?
    I'm trying to make a boot animation for finless 1.7c but I just get a black screen.
    I have one folder with the images in, all png 24bit (not sure if they should be 8bit)
    My folder structure is:
    Code:
    ./bootanimation
        desc.txt
            ./part0
            ./image000.png
            ./image002.png
            ./image003.png
            ./etc
    Contects of desc.txt are:
    Code:
    1280 720 36
    p 0 0 part0
    (36 fps means two rotations of a spinner in the animation)
    The resulting zip file is saved as "store"
    Am I doing something wrong?
    Make sure you have permissions set to 755 for the bootanimation.
    Randy
    Randy
