2) yes i found the right bootlader, thank your suggestion worked, just installed the app on the working box and checked the bootver
3)yes everything is fine, used the bootloader i downloaded form internet flashed it on, then i flashed all the other files that i dumped fromt he working box
4)yes i noticed there are proably 20 different boards etc, mine looks to be same as this, only thing i cant confirm is the cpu chip but im sure its the same, only difference mine is 1/8gig and the ones in the thread are 2/8gig. http://freaktab.com/forum/tv-player-...0-2013-12-05)= my board is engraved xt-q7-v11 2014-q7-14 im just trying to find out how to properly flash and it looks like its same way as i did the first time i guess windows 8 usb problem is my ultimate problem... or maybe not
5)after i brought the box back to live, i used all files i could get form the rom i initially tried to upgrade, so i unpacked it and simply flashed it on like i flashed on the original firmware files
5a) correct addresses if you mean location of the files to flash (yes). and yes right parts to right partitions (yes)
my ultimate goal right now is just to find a proper firmware to upgrade the box, so i can play video without stupid 20fps like stutter, if anyone knows any suggestions please feel free to share
thank you again all for your help and input, including cypher - i guess i will give it a try on an older computer thats not runnign win 8
