Rom tested on my cs928. I make some modifications new booimg add ap for root , remote work , wifi ok enth ok , camera ok ,Fast boot , farst boot will by mor long
ROM source CR13_cloudnetgo_T049_zhongwei_AP6330_20150429
Plumplum thank you very match !
It`s help ! I tried 3 different ROMs and was hopeless but your advice solve the problem !!!
:-) cool...
For me, it's not fully solved but it's far far better... Download a big file while playing music and you will see the problem back...
We are 3 to report improvement with this method :-)
