R7 Android TV Set Top Box
    Hello !
    I would like to ask for your help.
    I bought R7 Android TV Set Top Box TV Player Rockchip Rk3066 (1.6GHz Dual Core 1GB RAM 8GB Mic HDMI WiFi and ethernet port).
    (http://www.aliexpress.com/wholesale...art-TV-Set-Top-Box-HTPC-Allwinner-A10-1GB-RAM)
    I would like to install Samba server because I want to connect and share all media (audio and video) to home network. I can't install Samba server because I have not get root access.
    I have tried many programs and read a lot about this subject, but I could not find a solution.
    Each program tells you that the device is offline !!!
    I'll send you some pictures of the device.
Name:	About _the_device.jpg
ID:	438344Click image for larger version
ID:	438345Click image for larger version
ID:	438346Click image for larger version
ID:	438347Click image for larger version
ID:	438348Click image for larger version
ID:	438349Click image for larger version
    When I open the RockchipBatchTool and after "Connect to PC" the RKBatchTool should turn into Pink. This program is working but I don't know which rooted firmware compatible for my device.
    I made backup by using CWM. Can I rooting this backup and upload for box ?
    The cwm not create IMG file !
    Saved on SDCARD some different files.
    0 .android_secure.vfat.tar
    1˙536 .android_secure.vfat.tar.a
    16˙777˙216 boot.img
    0 cache.ext4.tar
    1˙050˙624 cache.ext4.tar.a
    0 data.ext4.tar
    388˙484˙096 data.ext4.tar.a
    8˙388˙608 kernel.img
    555 nandroid.md5
    16˙777˙216 recovery.img
    0 system.ext4.tar
    432˙399˙872 system.ext4.tar.a
    Does anyone know how I can to root the downloaded firmware ?
    Now I have a complete backup of firmware.
    When I started the root procedure and got the failed result so I started analyze the log file and bat file.
    Can you see below the complete batc file and attached prtsreen copy.
    pause
    adb shell id
    echo --- If the ID shows as 0/root then continue, otherwise CTRL+C to cancel and start over
    pause
    adb remount
    adb push su /system/bin/su
    adb shell chown root.shell /system/bin/su
    adb shell chmod 6755 /system/bin/su
    adb push busybox /system/bin/busybox
    adb shell chown root.shell /system/bin/busybox
    adb shell chmod 0755 /system/bin/busybox
    echo --- Installing SuperSU
    adb shell chown root.root /system/app/SuperSU.apk
    adb shell chmod 0644 /system/app/SuperSU.apk
    adb push RootExplorer.apk /system/app/RootExplorer.apk
    adb shell chown root.root /system/app/RootExplorer.apk
    adb shell chmod 0644 /system/app/RootExplorer.apk
    echo Completing Root
    adb shell rm /data/local.prop
    adb shell rm /data/local/tmp
    adb shell mv /data/local/tmp.bak /data/local/tmp
    adb reboot
    echo echo --- Reboot 3/3 - Your N101 II should now be rooted
    I thinking:
    If I put manually Supersu.apk and rootexplorer.apk and su and busybox files to saved firmware and upload to box the box will rooted ?
    What do you think ? Any idea ?
    I have many questions:
    How can I root this tv box ?
    How do I create a device administrator ? Need foir me device administrator ?
    Which ROM version compatible for this box ?
    Can you recommend me rooted firmware ?
    Many thanks for advance !
    Best regards !
    Peter
    Yes you can in fact make a new ROM using the downloaded firmware.
    I give all kinds of tips here:
      Hi Bob !
      Unfortunately, I am not an advance IT guy and just start learning the Android system. I'm sure that I can not create a new ROM.
      Just a question:
      If I upload the (Kimdecent B13 / MK812 with external Wifi Antena - Finless BETA ROM 1.7) that you made, chances are that it will work my box ?
      My tv box made by Kimdecent Technology from Schenzen.
      Peter
        Hello !
        Last night I restored the modified firmware (manually inject Superuse and SU binary to firmware) to my R7 android tv box, so now I have a rooted nandroid firmware !
        Everything is working properly. AnTuTu score there are of 9700 - 10200 between (I measured many times but the result were different always).
        If you need the rooted firmware to our R7 tv box I can help you !
        Peter
          Hello !
          Can you see below how can to create root access for your device:
          1.) Please download latest RK30GENERIC_CWM.zip from
          http://androtab.info/clockworkmod/rockchip/rk3066/
          Possible need to register for http://forum.xda-developers.com site
          (see the next topic:
          http://forum.xda-developers.com/show...2679&nocache=1)
          2.) Please download CWM-SuperSU-v1.25.zip from:
          http://www.androidfilehost.com/?fid=22900092470034675
          or
          http://goo.im/devs/crawrj/Android/Ep...erSU-v1.25.zip
          3.) Please download Reboot app from:
          http://www.freaktab.com/showthread.php?1050-Reboot-App
          or
          https://www.dropbox.com/s/oqkl6xovap...oot_v0.9.3.apk
          This application need for you later if you want to use CWM base recovery in the future.
          4.) Copy RK30GENERIC_CWM.zip and CWM-SuperSU-v1.25.zip to SDCARD (or USB drive) root directory. Plug to your device to power supply and wait the question: Would like the update from SDCARD. PRESS YES ! The device will reboot and install the CWM base recovery mode. When it was all right the device started to CWM recovery base.
          5.) FIRST STEP: create backup from your device ! (backup and restore item). The software made the backup to your device SD memory. Later you can to move these directory to anywhere.
          6.) Here you'll find some pages use the CWM software:
          http://www.themobimag.com/guide-inst...stom-recovery/
          http://www.addictivetips.com/mobile/...omplete-guide/
          7.) Select: install zip from sideload
          - chose zip from SDCARD - select and install: CWM-SuperSU-v1.25.zip
          When the installation is complete, the device has been rooted.
          8.) reboot system now
          If you get stuck you can write for me and I will answer for your questions.
          Kidmecent The company released the latest firmware with what can be found on the following link:
          If you installed the CWM base recovery software you can to upgrade your device with RKBatchTool.
          Sorry my english is not to good !
          Peter
