I am a little worried with your statements, it´s confuse to me the different opinions between you and hisound, he had said not to see any danger at all with those values.
After one of my beelink R89 (2G/16G-AP6335- PCB v3) had been unstable using wasser 3.0 rc 3 (lollipop) I had decided to test ugoos_stage2 released by hisound, and for the first time I had seen this device working properly without "stutter" during videoplayback (but still with a little micro-freezes on UI operations and mouse pointer movements). I had been working a couple of hours playing some 1080p videos with that rom and the device been stable without any overheating.
The change of the led colors from blue to red is lost on this rom (the led stay on blue in any condition, "on", suspend or sleep, and just off when the device is turned off) and the web cam (logitech c170 & c525) work but can not record videos; but the rest for me is the best performance obtained with this device, not reached with any of the previous rom tested; so that jump is obtained for the raise of voltage value going to the components of the board? is that condition really unsafe; why the device can work several hours without be burned working on those conditions? why the device is not burned immediately as soon that internal voltage limit of 1.4 V is exceeded?.
Now I´m usnig in the problematic R89 the ugoos_stage3 rom by hisound, and the performance is as good as on stage_2 but with improvements on youtube 1080p - 60 fps comparatively to stage_2.
On the second unit of R89 (as well PCB v3), that I had not find problems, that work with very good performance with lollipop wasser 3 rc3, so, definitely the R89 tv boxes had been released with different hardware problems each individual device, surely, assembly and productions problems.
