Can I use a usb hub on ug802 if I do a finless 1.7 install?
I'm totally new to android devices and want to get more than 1 usb thing running on my ug802 stick. When I plug in a powered usb hub into the full size usb, the device uses it for power and turns on. I plugged my wireless mouse adapter into the hub and it does nothing. If I do a 1.7 finless install will the power usb hub work with my wireless mouse adapter, usb keyboard, and external hdd?Tags: None
Re: Can I use a usb hub on ug802 if I do a finless 1.7 install?
Originally posted by guilds100 View PostI'm totally new to android devices and want to get more than 1 usb thing running on my ug802 stick. When I plug in a powered usb hub into the full size usb, the device uses it for power and turns on. I plugged my wireless mouse adapter into the hub and it does nothing. If I do a 1.7 finless install will the power usb hub work with my wireless mouse adapter, usb keyboard, and external hdd?REMEMBER, YOUR FEEDBACK IS VERY IMPORTANT TO US.My devices:
There are currently 2267 users online. 0 members and 2267 guests.
