Help needed to identify box please
Hi , I bought this box from ****, and the seller sent me a rom and I didn't bacj up the original rom, I cannot get wifi or Ethernet with it since the flash and the seller is ignoring me on ****, there is nothing to identify the board, one chip has rk1000-s the others are too small to see. the image I got sent had this file name "X6-4.4-jingying.img", sent because xbmc didn't function. this is the advert title, "CS918 Quad Core 4.2 Smart TV Box Player XBMC HDMI WiFi 1080P 2GB 8GB UK", I can't get into the details anymore, I have tried a couple of roms with no luck, this was a present for my son so I am annnoyed its advertised as the 2gb model any help greatly appreciated update found more info i forgot about, addeed extra pics, the image says 2gb but sticker on underside of PCB says 1gb! sticker on bix with support , the accounts stated do not work!You may only view thumbnails in this gallery. This gallery has 4 photos.4 PhotosTags: None
I don't know about which sticker you talk, but the 2GB could be a fake (via the kernel and swap) and the 1GB are the real physically existing ram...
The 2. picture is the picture which could help IF it would be a better quality, but I think I can read ZY_X6_V21 2014_09_20 at it, and this would be the information you need to find out if another rom exists...
http://freaktab.com/forum/tv-player-...v-how-to-start
RK3288 Devices
- Overview BOX (LINK !)
thanks for the reply and info, the sicker I mentioned is on the underside of the pcb, sry I didn't make this clearer
I now have a nother problem the last flash I done failed, and now when I connect box with RKbatch tool it connects and disconnects will not stay connected, drivers are fine and I have tried another usb cable and usb outlet, but still no proper connection, any ideas?
rk log file
Code:14:01:42 184 Èðо΢Á¿²ú¹¤¾ß v1.6.8.1 start run 14:20:43 373 Èðо΢Á¿²ú¹¤¾ß v1.6.8.1 start run 14:24:22 536 **********Upgrade Start Total<1>********** 14:24:22 536 <Layer 2-4> Test Device Start 14:24:22 536 <Layer 2-4> Test Device Success 14:24:22 536 <Layer 2-4> Check Chip Start 14:24:22 536 <Layer 2-4> Check Chip Success 14:24:22 552 <Layer 2-4> Get FlashInfo Start 14:24:22 552 <LAYER 2-4> INFO:FlashInfo: 0 0 9 1 0 20 20 28 20 2 1 14:24:22 552 <Layer 2-4> Get FlashInfo Success 14:24:22 552 <Layer 2-4> Prepare IDB Start 14:24:22 552 <LAYER 2-4> INFO:CS(1) (8480MB) (HYNIX) 14:24:22 567 <Layer 2-4> Prepare IDB Success 14:24:22 567 <Layer 2-4> Download IDB Start 14:24:23 474 <Layer 2-4> Download IDB Success 14:24:23 474 <Layer 2-4> Reset Device Start 14:24:24 491 <Layer 2-4> Reset Device Success 14:24:24 491 <Layer 2-4> Wait For Loader Start 14:24:55 030 <Layer 2-4> Wait For Loader Fail 14:24:55 030 **********Upgrade Done Success<0> Fail<1> Time<32500>ms********** 14:26:12 159 Èðо΢Á¿²ú¹¤¾ß v1.6.8.1 start run 14:27:45 584 Èðо΢Á¿²ú¹¤¾ß v1.6.8.1 start run 14:29:18 475 Èðо΢Á¿²ú¹¤¾ß v1.6.8.1 start run 14:32:17 753 Èðо΢Á¿²ú¹¤¾ß v1.6.8.1 start run 14:33:47 063 Èðо΢Á¿²ú¹¤¾ß v1.6.8.1 start run 14:37:29 031 Èðо΢Á¿²ú¹¤¾ß v1.6.8.1 start run
I don't know if it will also help at this box, but I know the same situation at a rk3288 device and I handled it the way, that I began to flash at this short time windows where the connection exists and of course it crashed but after that the next time it doesn't lost the connection...
Worst case maskmode: http://freaktab.com/forum/tv-player-...07-Q7-bricked=
RK3288 Devices
There are currently 1496 users online. 1 members and 1495 guests.
