Cx-919ii clone bricked. Need compatible rom, Help!
    Im very disapointed, i bought a clone on **** for 42€. I need help now finding a compatible rom for this rk616 chip.
    The model is: gxt_g16_lp_v1.3
    When i plug it now to the tv theres no sinal, the screen goes black, no boot shows up, nothing happens.. It was working before i tried to install a New rom, but i Just wanted to change it because the streams where crashing alot on kodi.
    Hope anyone can help me,
    MK808b Plus @ gearbest
    I have the same device.
    Did you find rom
      No... i sent it back to the seller now im waiting for my refund :/
        This has to be one of the hardest tv sticks to find a working rom for as there is that many different pcb (clones) ..I think you need to buy them as soon as the come to market to avoid buying a clone
          You are correct. And buying them from **** is a big mistake
            Check this website www.chinagadgetsreviews.com they have a lot of clone firmware in the download section. Just search for your device.
              I have a differnet one but very similar (GXT_D16_LP_V1.8 150310) and fixed it via http://freaktab.com/forum/tv-player-...think-cx-919ii
