I have IXT-Q7-V11 2014-07-14 (1g/8g) R-Box running on android, I try connect the device to my PC but is imposible. I try with different pc and nothing. One pc has windows 7 and other xp. Unknown device. I try with release driverassistant and the same. Unknown device:Windows has stopped this device because it has reported problems. (Code 43) . please help me.
unknown device
unknown device
Hello
I have IXT-Q7-V11 2014-07-14 (1g/8g) R-Box running on android, I try connect the device to my PC but is imposible. I try with different pc and nothing. One pc has windows 7 and other xp. Unknown device. I try with release driverassistant and the same. Unknown device:Windows has stopped this device because it has reported problems. (Code 43) . please help me.Tags: None
Things to try.
1.Make sure you use a USB2 port & not USB3 port
2.Use the usb port at the back of your pc & not the ones on the front
3.Try another usb lead some do not work (This could be your problem)
4.Drivers sometimes they can be a nightmare, completely remove them & install them againPlease consider making a Donation to freakTab
Thank you for the answer. I am trying with a laptop windows7, lenovo G 50. I try with all different ports and unknown device.. And sorry all the time I am trying whith laptop. Regards
And I have other device cs918 not detect nothing the lsptop( the same, unknown device)Last edited by fotomiron; 15 May 2015, 21:03.
you can also try these driver http://freaktab.com/forum/tv-player-...361#post323361 and you also should have a look at http://freaktab.com/forum/tv-player-...-box-read-this
RK3288 Devices
- Overview BOX (LINK !)
There are currently 1861 users online. 3 members and 1858 guests.
