This new Box has an AML S812 CPU, the only Main difference to the S802 is Multi-format 4K2K, H.264 and H.265 UHD hardware Decoder.
Same as S802 but adding H.265/HEVC video decoding up to 4K and Gigabit Ethernet. This makes it more future proof than S802, and it
could potentially be used as a media center with a USB hard drive and Gigabit Ethernet connection.
Here are the Tech Spec´s of the Device:
- S812 Quad-core Chip
- Excellent performance with S812 Quad-core processor, Octa core GPU. Adding H.265/HEVC video decoding up to 4K, Could be also used as a pretty good gaming platform or a media center.
- Android 4.4
- Enjoy customization on the highly evolved Android Kit Kat 4.4. Enjoy the best of Google with voice commands, hangouts app and Google Drive to ease your life.
- 2GB RAM & 16GB ROM
- Powered by 2.0GHz Quad-core processor.Stop restricting yourself to just one app at a time as the 2GB RAM lets you multi task effortlessly.
- Eshare Function
- It's a multi-screen interaction application for smart phone or tablet to interact with TV
- Pre-install Video Software
- Pre-install XBMC media center,XBMC can be used to play almost all popular audio and video formats around. you can stream your multimedia from anywhere in the house or directly from the internet.
- Net weight: 196 g / 6.91 oz
- Size: 115 x 115 x 26 mm / 4.53 x 4.53 x 1.02 inch
But from the Spec´s you see it is a Real Good Device.
If you want to get yourself one go here
Freaktab.com
