Flocked up, wrong rom?
Saw that shinny 2.0 on KitKat Finless ROM 2.0 thought that must be the latest/greatest and flashed my mk908II with it, everything worked "fine" but no wifi or bt, now I'm thinking the 428 in the name = screw-up. So on closer look MK908-II - Finless 1.6 ROM seems to be what I wanted, now how to get thar from har? Settings only has usb debug, no connect usb, so how do you connect via usb? Second method sd card update while holding update button gets twrp recovery not bulit-in update, is their a way to use the sd update, or can I flash from within twrp? None of the files seem to be zip updates which is the usual twrp update method?? Any guidance?? ThanksTags: None
So I figured boot with the 4.42 sd rom and get at it that way, it has the "usb connect" but no usb debug, no dev. option at all it seems, so the computer sees it but not the flash tool. Maybe I can copy the correct wifi drivers to the nand from here? If yes, any ideas on what exactly needs to be replaced??
There are currently 2831 users online. 0 members and 2831 guests.
