Restore Kodi backup to Open Elec
Yes there is, you need to download xbmc backup from program addons and SET IT UP (c or menu button): Browse to the backup folder (added by you) and select what things you want backed up. Once done, open the addon (click on it) and from the popup menu select backup. That's it. Then in OpenElec machine you need to copy the folder of the backup to it, then download xbmc backup addon and do the same procedure BUT INSTEAD select what you want to have restored and browse for backup folder you just copied. fInally open the xbmc backup addon and from the popup menu select restore.
There are currently 4588 users online. 2 members and 4586 guests.
