Sorry if this question was asked before..
Android on USB for X7. Possible?
If you have a look over here http://freaktab.com/forum/tv-player-...indows-minipcs it has been sort of done but its not quite working right on the x7 but least you can give it a try the more people that try it the better.
BlinkonePlease consider making a Donation to freakTab
Sorry but I think you misunderstood my intentions. Firstly I'm not a rom developer and my knowledge on software are as good as none.
I've been following that thread and the firmware does not work ok because its based on other box.
Pipo X7s does come with Android albeit without Playstore, so if we can use the original X7s Android firmware to make it boot from USB for the X7, then I believe it will give current X7 owners flexibility to run Android.
Hallo, probier das Programm einmal aus. Läuft super auf meinem DELL Venue 8 Pro, sollte auf dem Pipo auch funktionieren
Hello , the program try out once . Runs great on my Dell Venue 8 Pro , should work on the Pipo also www.amiduos.com
There are currently 2651 users online. 1 members and 2650 guests.
